Results 1 to 7 of 7
    Aug 2005
    West Sussex
    45
    EXACT DIFFERANCE BETWEEN 210 AND 225 BHP ENGINES
    COULD SOMEONE PLEASE ANSWER MY QUESTION OF THE EXACT DIFFERANCE BETWEEN 210 AND 225BHP ENGINES ,IS IT VARIABLE VALVE TIMING AND CAN A 210BHP PRODUCE THE SAME POWER WHEN REMAPPED AS THE 225 OR WILL THE 225 ALLWAYS HAVE A 15BHP LEAD WHEN THE SAME WORK IS CARRYED OUT FEEDBACK APPRICIATED <font color="blue"> </font>
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    Re: EXACT DIFFERANCE BETWEEN 210 AND 225 BHP ENGINES
    noth will produce the same power once mapped (about 260bhp ish)
    the only difference as far as i know was the OEM mapping making one 210 and one 225.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    not quite right, I'm sure someone will post the correct answer, but the first 210BHP engine the APY had mechanical VVT, the later were electronic. there are also some component differences, I believe the APY (210) engine has the strongest con-rods, there are other little changes too but nothing dramatic.
    they are very similar when mapped, but if your going for BIG power then the 210 is supposed to be better talking over 350BHP.
    hope that helps.
    Aug 2005
    West Sussex
    45
    THANX 4 REPLY
    Aug 2005
    West Sussex
    45
    CHEERS 4 REPLY THATS JUST MADE ME THINK I WILL GO 4 A 210 MODEL
    robthehungrymonkey's Avatar
    Apr 2004
    Uckfield, Near Brighton
    555
    SO what's the difference between an AMK(210bhp) engine and a BAM(225bhp) engine?
    Jun 2004
    Crowthorne, England
    2,512
    yep just as I thought, AMK must be as close as you get to BAM with a different ECU if you look at the below from the other post it appears that AMK has electronic VVT.
    APY
    Date: 11/98 - 09/00
    Drive: Haldex 4WD
    Emission: VVT (mechanical), EU3
    Throttle: drive-by-wire
    Injectors: big
    Turbo: K04
    Gearbox: ? (6-speed)
    AMK
    Date: 09/00 - 04/02
    Drive: Haldex 4WD
    Emission: VVT, EU3
    Injectors: big
    Turbo: K04
    165 kW (225 bhp) Engines in S3
    BAM
    Date: 08/01 - 05/02
    Drive: Haldex 4WD
    Emission: VVT (check), EU3
    Injectors: big
    Turbo: K04
