Badger5JBS
    Nov 2011
    46
    Post Thanks / Like
    VAGcom and engine check light
    recently the GF's 1.8T A3 threw up an engine check light, took it to a mates and he plugged in his VAGcom and came up with some error code, i don't recall what it was but gave a description along lines of :
    air leak between AFM and throttle housing.
    at more or less the same time "service" flashed up on the display.
    the following day it went in for a cam belt change and we asked the garage (not Audi btw) to remove the "service" indicator because it will be done within the next week or so.
    so got car back and the "service" indication was still there but they had reset the engine check fault code, so no engine check light, got the car home and whipped off engine cover and sure enough found a breather hose from rocker cover to inlet had a bloody great split, replaced the pipe with a new item and everything's been fine.
    ..until today the engine check light came on again, the GF took it to a local garage and the said the original fault has come back.
    so the mechanic took it for a test drive, came back ad proclaimed the car felt fine, but when he re-plugged the computer into the car it didn't give any fault codes, and then the engine check light went out (i assume without him resetting it)
    firstly why would the fault reappear? (as in check light) despite 5 mins prior giving the same fault as above, and then later not showing up at all?
    secondly is it even possible for the check light to go out on its own accord?
    Jan 2011
    northants
    84
    Post Thanks / Like
    clean and reset throttle body
    check vacuum and breather hoses fitted below inlet manifold
  1. Engine managment light what to check??
    By littlerick in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2011, 12:11
  2. engine check light
    By audii in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th August 2007, 17:23
  3. Check Engine Light
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2006, 22:27
  4. Check Engine Light
    By Bliz35 in forum General Technical / How To
    Last Post: 15th November 2004, 19:39
  5. check engine light
    By imported_mikee111 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2004, 09:51
