DNA TuningJBS
Results 1 to 10 of 10
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    772
    Post Thanks / Like
    Unresponsive door handle?
    Hi.
    This morning my passengers exterior door handle didnt want to work.
    Im guessing its due to the low temperatures, as the interior handle still worked fine.
    The handle flet like it had no resistance against it, just wondering if this is a common fault when the weather starts freezing?
    Is there anything i can grease/ lubricate to prevent it in the future?.
    Regards
    (If anyone has access to an exploded diagram of how the rods/ handles lock attaches to the latch, this would be very very handy)
    Banned
    437
    Post Thanks / Like
    I had the same thing last week and a good spray with WD40 up and around the lock unit with the straw on the can whilst working the handle has solved it for now.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,405
    Post Thanks / Like
    my passenger door lock doesnt seem to pop open fully, the pin struggles to reach its maximum erection from the door card
    Dolphin Grey 2002 S3 (BAM)-SymII phatnoise BOSE-alloy mirrors/aerial/door pins-TT pedals-Full aero wipers-chrome indicator bulbs-privacy glass-Forge DV-Samco TIP-BMC panel filter-stage 2 Jabba remap-R32 arb's-super pro/powerflex bushes all round
    Wanted for above:
    Rear bumper grey panel insert
    Brand new drivers side headlight
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    772
    Post Thanks / Like
    a3tdi2001 - is that around the mechanism with the doorcard off?. or simply in the latch area?.
    mattyboy199 - have you tried it with the pin unscrewed to see if thats catching?
    Banned
    437
    Post Thanks / Like
    Just up and around the inside of the latch from the outside. Might take the doorcard off in the warmer weather if it reoccurs but it's been fine for now.
    Nov 2005
    UK
    1,405
    Post Thanks / Like
    i have alloy door pins fixed with lock tight so need to investigate, but its been fine for years up until now.
    Wanted for above:
    45_CB's Avatar
    8L S3 BAM
    Nov 2011
    South West UK, Devon
    45
    Post Thanks / Like
    I had to yank my door open this morning because of the ice...
    Then I got in, shut it and it was like the handle was still held open as it fell away from me instantly! Had to start my drive to Plymouth HOLDING my drivers door!
    Opened and tried shutting and by Yelverton it shut, I spray lubed both door catchs and used a screwdriver to operate the latch open and shut a few times whilst spraying... JOB JOBBED, Now perfect
    45_CB's Avatar
    8L S3 BAM
    Nov 2011
    45
    Post Thanks / Like
    Scrap that Callum... got in this morning, shut the door and it only caught the first catch, tried again as it seemed I didn't shut it properly... Again first catch, now it WILL NOT close
    WTF is wrong with Audi, surely closing a DOOR is quite standard
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    772
    Post Thanks / Like
    lol.
    sounds like yours could be a faulty latch CB, i had this soon after i bought my car - it would only secure on the first catch unless i slammed the door.
    45_CB's Avatar
    8L S3 BAM
    Nov 2011
    45
    Post Thanks / Like
    I have changed my spray lube to silicone based oil and drenched it...
    Working better than before now :-) also fixed my rear washer which came apart from behind the airbox and had a blocked nozzle... ahhhh S3 ownership lol
  1. Anyone with a door card or interior "door handle/door arm rest" for sale
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2011, 17:37
  2. A6 Door Handle
    By Shawsy in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 9th November 2008, 11:43
  3. drivers interior door handle not opening door
    By obitus in forum General Technical / How To
    Last Post: 20th May 2008, 15:52
  4. Internal Door Handle Not Opening Door?
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2008, 20:14
  5. o/s/f inner door handle.
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2006, 19:08
