on the little screen on the dash it doesnt tell me the temp outside .. should it? just seen a pic of an s3 which is older than mine and its showing the outside temp? is it only s3's tht do!?
cheers
cheers
I would think that it should have it, maybe non turbo a3's had to have it as an extra, do you have the display in the centre of your dials?
2002 51plate Audi A3 1.8T sport AUM, Minger blue, xenon conversion, piano black recaros, forge 007p, jet ex filter, cold feed, silly tip. That's the good stuff listed
i have got a display when i start the car it says ok! but then just goes off...
I've got the same display on a 2001 TDI Sport, with the big orange OK at start up. It doesn't have the outside temperature, mpg etc function. Just the doors open, OK, service mileage when it becomes due, and standard warning symbols.
press the button on the right hand stick its like on the under side of the stalk then it should come up![]()
AARON77 liked this post
Ahh another one for the 1.8t :D
wheatobear liked this post
A3 T liked this post
You need to code it in using VAG-COM, see here:
External temp dispay on dash
'02 A3 TDI quattro sport![]()
8L IS DE BEST
