AMD TechnikUnicorn
Results 1 to 12 of 12
Thread: Spacers
    Apr 2011
    Gloucestershire
    223
    Post Thanks / Like
    Spacers
    Hi guys within the next 2 weeks i'm going to be buying some 18" calibre vintages for my car, i was wondering how big spacers i can go for on my a3 ? i'm as low as possible now and will be on them and i want it as fat as possible
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    Im guessing its a case of fit them without spacers and guage it from there.
    What offset are the new rims?
    I have an S3 so my numbers willnt realy help but i run 15mm rear spacers and 10mm front on ET32 wheels meaning im realisticaly running ET17 rear and ET22 on the front.
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Miltek cat back exhaust
    3inch down pipe and decat
    stage 2 short shifter
    Forge TIP , Boost hoses and DV
    3.8 bhp /40.7 torque
    huge cock on my head
    Apr 2011
    Gloucestershire
    223
    Post Thanks / Like
    the offset is 35 mate
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    I would expect 10mm all round would be doable but... not sure what a realy low A3 would catch on, Also what tyre size have you got planned? 225/40/18 an an 8j wheel??
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
  6. Thanks N4THW thanked for this post
  7. #5
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,689
    Post Thanks / Like
    What width are the wheels?
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
  8. #6
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    18" 1J ET35 5x100 you would probably need 100mm spacers, hubcentric mind and longer wheel bolts...
    tyres? 25/360/R18 if you can find them
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  9. Thanks N4THW thanked for this post
  10. #7
    Apr 2011
    Gloucestershire
    223
    Post Thanks / Like
    thanks everyone.
  11. #8
    Apr 2011
    Gloucestershire
    223
    Post Thanks / Like
    Rim Width: 8J
    Stud Diameter: 100
    Rim Diameter: 18
    Rim Structure: One Piece
    Offset: 35
    is the info on the wheel
  12. #9
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    are you current wheels sitting miles inside the arches?
    Alex S3 AMK
  13. #10
    Jun 2010
    Milk n Beans (Milton Keynes)
    105
    Post Thanks / Like
    I have a pair of 10mm FK hubcentric spacers for sale if you want em? No bolts though.
  14. #11
    Aug 2010
    633
    Post Thanks / Like
    i have coilovers all the way to the bottom on rear (adjuster still fitted) and front matched (inch or so from bottom on joms)
    et35 18x8j with 225/40/18. had to fit audi tt anti roll bar. just about knocking chassis leg on hard left hand cornering.
    i have 10mm spacers on front and 16mm on back.
    front arch lips had to be rolled. front and rear have worn through the plastic arch liner. fronts hit front arch liner where it attaches to the bumper too. it also rubs on the inner arch near the engine if that makes sense. rears rub on big dips as do fronts.
    i did have 5mm on front and 10mm on rear with no rubbing. but the inside of the tyre rubbed the coilovers.
    basically lots of rubbing but it goes away once plastic has worn a bit. looks ace imo pain in the arse it what others will say.
    Genuine Audi Pink A3 1.8T, stage 1 remap. Genuine Audi bodykit and Reiger front bumper, 18's, JOM coillies down 50mmish, dewipered, debadged, 007P, K&N, Janspeed exhaust, Bose and a few other bits and bobs!
    WANTED: rubber mat which sits under ashtray in cubby hole
    drivers side wing mirror glass,
    bonnet in Devon area
    front brake discs for A3 1.8T
  15. #12
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,689
    Post Thanks / Like
    With your wheel size I'd say go for 10mm front and 15mm rear.
    DPM Performance
    T: 01207 561606
  1. Spacers
    By Chappy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2011, 10:08
  2. Spacers please help
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2011, 21:41
  3. Spacers
    By s3_stig in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2010, 18:19
  4. 17.5 mm Spacers
    By Maq in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th March 2010, 10:26
  5. Spacers - again !!
    By richs2891 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd December 2007, 21:27
