KowalskiDNA Tuning
    Jan 2012
    Truro, Cornwall
    168
    Post Thanks / Like
    Just cant work out what the problem is!
    Hello everyone
    Ive been having problems with my fuel gauge on my 2000 S3........
    I will fill my car right up to the brim and everytime, without fail the fuel light will come on and the gauge will read empty. The gauge and light will remain the same until i have done 100 miles approx (changes everytime) then it will normally go to a full tank, the light will also go off and the gauge stay there until ive got about a quarter of a tank left and it will drop to a quarter of a tank and wont go any lower, even if i run out of fuel.
    I have fitted a new fuel tank unit.......that didnt work!
    I then did a bit of research and found that a common fault is the cluster display......the LCD screen would have lines through it, the speedo and other gauges would also become faulty/incorrect. My LCD screen had lines through it but i wasnt sure about the other gauges.......anyhow I sent my cluster display off to BBA-Reman as I thought i might as well get the LCD screen replaced and see if there are any other faults.
    Unfortunately they said there was nothing wrong with the fuel gauge on the unit but AT LEAST I have a nice shiney LCD screen that i can read now! haha
    Now im back to square one!!
    Anyone have any ideas with what could be wrong?
    Scott
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    By fuel tank unit do you mean the whole thing that sits in the tank? ( got to under the rear seat of the car )?
    I though the level sensor was in there? Is the breather to the tank open and clear? i only ask this as a woman i know has a golf 4motion that had issues with the gauge reading full and her only being able to half fill it because the tank basicaly needed to burp.
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Miltek cat back exhaust
    3inch down pipe and decat
    stage 2 short shifter
    Forge TIP , Boost hoses and DV
    3.8 bhp /40.7 torque
    huge cock on my head
    Jan 2012
    Truro, Cornwall
    168
    Post Thanks / Like
    Quote Originally Posted by S3 Paul View Post
    Hello
    Yes it was under the rear passenger seat. Hmmm thats interesting. Im not sure, will have to look
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    sounds like a faulty tank level sensor to me
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    Mine got stuck once , But after changing the pump ( inside the unit with the sender on) its been fine
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Fuel pump lag - there was a similar issue with my mates 1.8t golf.
    Uprated the pump, new sensor, and fuel filter. Dumped a bottle of red-x in it. Perfect ever since
    Marcus
  1. Work on the S3 problem free until....
    By jdas03 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2010, 21:59
  2. Poseidon Infosoft: Genuine Work at Home,Genuine Data Entry Work
    By tf2010r270 in forum The Welcome Section
    Last Post: 14th July 2010, 07:50
  3. Problem at work....
    By jb0o in forum Rants & Raves
    Last Post: 6th January 2010, 14:24
  4. Headlight washer jets dont work, what could be the problem?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2009, 10:21
  5. Having problem getting USB cable to work with VAG.com
    By Rev-head in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th August 2007, 17:53
