KowalskiVAG Check
Results 1 to 7 of 7
    Apr 2011
    London, United Kingdom, United Kingdom
    101
    Post Thanks / Like
    battery positive lead
    just been to my mechanic and noticed my battery lead to the starter is badly corroded and green where he says its rotting. i've been suffering from a slight voltage drop which could be caused by this. can i add
    Halfords | Halfords Positive Battery Cable 45cm (18")
    as and additional cable to the starter or would i have to remove the old one completely? tps want £50 for a replacement terminal and lead
    Sep 2011
    tiverton
    291
    Post Thanks / Like
    seems expensive, would have thought you could get one made up for far less
    Apr 2011
    101
    Post Thanks / Like
    yh that's what i thought. i brought the lead from halfords for £5 so will see how that gets on
    Sep 2011
    tiverton
    291
    Post Thanks / Like
    dont know what the s3 lead is like, but on mine (tdi 110) the lead goes from the positive to the starter via an earth point on the chassis, so you may want to double check
    32
    Post Thanks / Like
    How can the positive go via an earth point?!! You must be looking at the wrong cable!
    Sep 2011
    tiverton
    291
    Post Thanks / Like
    ha ha yeah sorry i was being retarded for a minute there, forget that last comment i made
    Apr 2011
    101
    Post Thanks / Like
    all done now but haven't really noticed a sifference. i'm gonna do the grounding points next when the weather gets a bit warmer
  1. Is there anyone got anything positive to say about the A3 2.0tdi Quattro ?
    By Baza1819 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2012, 19:55
  2. Can you 'upgrade' the micro can lead to a hex can lead
    By pns2007 in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th September 2009, 19:40
  3. something positive for a change
    By voorhees in forum General Chat
    Last Post: 4th May 2009, 10:16
