DNA TuningW8 Performance
    Sep 2010
    404
    Post Thanks / Like
    Altenator belt tensioner jumping up and down.
    In regards to my last thread on here I replaced the alternator pulley as it was stiff and was making some horrible noises. This is now fixed thanksfully . However the belt tensioner still jumps up and down a little when the engine is running.
    Is this a major problem? Will a new one fix the problem?
    Dec 2006
    17
    Post Thanks / Like
    Hi, I had a similar problem on my Tdi 130, problem seemed worse at idle. Replacing the tensioner pulley fixed the problem hth
    Sep 2010
    404
    Post Thanks / Like
    Apart from jumping around, was there any other problems with it? I bought a new tensioner in case the alternator pulley was ok but don't know wether or not to put it on or return it.
    Welly's Avatar
    8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    10,175
    Post Thanks / Like
    Quote Originally Posted by doublem_1 View Post
    A bit of movement is normal, the belt will be stronger and weaker at points and will require more and less tension. Not unusual at all.
    "When I held that gun in my hand, I felt a surge of power…like God must feel when he’s holding a gun."
    Homer Simpson
    Welly & Bumble
    FP Green - 445 BHP/328 LBFT
    Badger 5 Edition....
  1. Help please - aux belt tensioner
    By Ian_83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 18:56
  2. timing belt tensioner
    By nightyx25 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th November 2010, 09:28
  3. belt tensioner
    By dingit in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 8th July 2010, 09:20
  4. Fan belt tensioner.
    By Cviji in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2008, 18:05
  5. Cam Belt/Tensioner Change
    By imported_shipp in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 2nd January 2005, 00:55
