Badger5DTUK
Results 1 to 19 of 19
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    OEM Digital Boost Gauge and Extras
    Interesting little digital gauge that replaces the dash clock:-
    Zada Tech - Audi TT, A3, S3, RS3, A4, S4, RS4 Red LCD Multi Gauge - OEM Looking
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Down side of this is will only work with ME7/facelift cars, otherwise a good little mod for something smart and discreet. I saw these a while back, there is a pre facelift S3 knocking about somewhere which has an analogue gauge plumbed into the original clock's place which is nice.
    I like him, he's my friend, and no amount of internet muppetry is going to change that I'm afraid
    But I wish I had an S3
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    I personaly like the idea of the gauges being up in clearer line of sight
    So i mounted my boost gauge on the A Pillor
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Miltek cat back exhaust
    3inch down pipe and decat
    stage 2 short shifter
    Forge TIP , Boost hoses and DV
    3.8 bhp /40.7 torque
    huge cock on my head
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    Quote Originally Posted by 16Klappe View Post
    Why is that then?
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Quote Originally Posted by Barks View Post
    Why is that then?
    The earlier ECU's have absolutely no way of registering the requested and actual given airflow or boost pressures. They are incredibly dumb. SHOULD work with most functions on S3's but I know there are a fair few S3's especially early cars which do not have the same sensors.
    I am 99% certain that the kit that comes with that does not come with the required sensors to get ALL of it's functions working on an older Ecu.
    Also the Bluetooth will certainly not work with earlier cars because they lack the appropriate protocols to process the data, I have Torque Pro and a OBD Bluetooth unit and it just refuses to work. The Torque App and 15 quid bluetooth sender will do a better job than this setup, just won't look as good and will be on your phone.
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    Link to the Blue tooth sensor?
    I looked at some of these a while back but couldnt make my mind up
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    I didn't think it used any of the OBD info, thought it was just uses standalone sensors
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    Quote Originally Posted by S3 Paul View Post
    Yeah agreed
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Pretty certain it plumbs into the OBD ports the same as Liquid does but the sensors are available as an extra for non compliant cars?
    Zada Tech - Boost Pressure Sensor
    Regardless of wether it plumbs in to it or not, the analogue clock would still make my argument stand
    Mar 2011
    Warwickshire.
    238
    Post Thanks / Like
    16klappe, hello there. Have you managed to get the boost gauge working on Torque as I thought this did not work with VAG cars yet. Was something the torque devoloper was working on when I last read the Torque forum.
    Cheers.
    A3 Quattro Sport
    Forge 007p Pipercross panel filter R-Tech stage one map (210BHP)
    Oil catch can mod, SIA delete, EGR valve delete. Forge EGR delete plate.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Quote Originally Posted by TheNewt. View Post
    Cheers.
    Works fine on my girlfriends car, which is a facelift.
    Which sender do you have and is it's software and driver up to date? I have the ELM237 sender.
    This forum from March 11 says it works - TORQUE android app now has boost for audi/vw!!!!!
    Mar 2011
    Warwickshire.
    238
    Post Thanks / Like
    I done a re-intall on my Android and had to reinstall torque so I gather I have the newest update as I only done it last week. I have the cheapo ebay bluetooth obd2 sender, not sure of what model number it is.
    Hoping this will work with mine now, it's a good bit of kit Torque is imo, will have to check and see if it works my boost readings now as it didn't when I tried it last year. Also mine is a facelift.
    P.s sorry for the thread hijack Barks.
    A3 Quattro Sport
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Yeah it works really well, mine has paid for itself tens of times in doing vagcom reads for favors at the side of the road of at meets for friends!
    I have a GPS app called Speedview Pro which coupled with Torque gives a very good tracking tool for track days/fast road and timings. All on my phone for less than 30 quid, awesome!
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    I can't see any mention of OBD anywhere, and how does your argument stand or am I missing something? (No argument??)
    Mar 2011
    Warwickshire.
    238
    Post Thanks / Like
    I too have cleared loads of friends engine lights with mine, they think i'm great as they are not paying garage prices for clearing fault codes and give me lots of beer, mmmm beer.
    I'll have to get that other app too, cheers for the heads up, quick coffee then out for a quick blast, nice one mate :L
    A3 Quattro Sport
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Well it just wouldn't fit, because there is an actual clock not an LCD screen
    That unit is designed to go in place of the clock, with the mileage removed the clocks would be scrap/not work.
    It looks like it has been upgraded from when I looked (years ago!) and now comes with a central control unit.
    Looks like a bulky control unit, and it requires a joystick to be plumbed in somewhere so would be tricky to install neatly.
    Still would look awesome if put in professionally,
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    Ah I didn't realise you were talking about a A3. I have a S3 preface lift with a digital clock, so it wouldn't be a problem.
    Good photos you haved loaded of the kit, I think the price would soon add up if you wanted a boost gauge, oil pressure and temp sensors
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    A lot of pre facelift S3's have a clock too, only the ones right on the switch over have a mix up.
    For the price of it, I'd have the more accurate, better fitting, more DIY friendly and better supported Liquid gauge.
    Awesome - Liquid Gauge & Diag. Tool - TT Mk1
    Mar 2011
    Warwickshire.
    238
    Post Thanks / Like
    Yep my boost gauge on the Android now works :D 22 according to Torque but maybe needs a tweak, oh and a quick blast with the correct weights gave me a 186bhp at 5511rpm.
    Cheers, good luck with the boost gauge hunting Barks
    A3 Quattro Sport
  1. OEM look boost gauge?
    By KB in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2010, 13:16
  2. OEM Digital TV Tuner
    By Jay.Ing in forum In-Car Entertainment
    Last Post: 18th May 2010, 17:10
  3. Digital boost gauge?
    By berglin in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2006, 18:09
  4. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
