VAG CheckKowalski
Results 1 to 9 of 9
    sideways steve's Avatar
    Dec 2011
    258
    Post Thanks / Like
    Advice Required - Vag Com Log
    Evening folks, I finally got around to logging the S3 as I have been feeling that its not been performing as it should.
    No codes logged at all however I think this log looks a bit odd ? Im suspicious of the boost pressures requested and achieved as well as the airflow. Im calculating that its running around 189bhp ish so down on power ?
    Car is stock, stock map but does have 3" DP and sport cat.
    Let me know your thoughts please, does this log look ok to you ? I started the run in 3rd gear from 1000 rpm roughly and held it until the red line before shifting to 4th briefly then backing off.
    Dec 2011
    258
    Post Thanks / Like
    Dec 2011
    258
    Post Thanks / Like
    According to what I am seeing I'm making 0.9 bar of boost when idling ? that doesn't sound right to me, nor does 1.7 bar when on boost ? Airflow's look low too ?
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    820
    Post Thanks / Like
    It takes into account atmospheric pressure which is 1 bar +- a little bit depending on where you are so just subtract 1 bar to give you boost pressure
    BAM S3, MTM K26 With External Gate, Hayward & Scott Custom Downpipe & Decat, Custom 3" TIP & Jetex, Lots of Silicon & Alloy Piping, Supersize DV, Southbend Clutch & Single Mass Flywheel, WMI, Porsche 6 Pots, 300mm Rears, AH Fabs V2 FMIC and to much more to list
    Power & Torque 335bhp 285ftlb
    My Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Dec 2011
    258
    Post Thanks / Like
    I was going to say ! LOL so the VCDS log shows absolute pressure rather than gauge, that makes more sense however still doesn't explain my low airflow's
    www.badger5.co.uk
    May 2004
    nr Glos
    3,851
    Post Thanks / Like
    requested boost is'nt being met... close but not getting quote there.
    check for usual leaks
    Big Brakes, AP Racing, Brembo, Ferodo DS2500/DS3000, Motul RBF660, Remapping, Dyno Tuning & logging, Big Turbo conversions, bespoke fabrication, Race Proven/Winning products and services.
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
    Dec 2011
    258
    Post Thanks / Like
    Hi Bill,
    Thanks for your input, I will get under there tonight when I get home and have a poke about. I assume by the usual leaks you mean all the vac pipes etc around the TIP ?
    I am also planning to buy one of your TIP kits in the near future but I want to get everything running as it should in stock trim before going down that route to ensure I get the most out of any mods I do.
    I assume if i resolve why the boost is not meeting the requested duty then I should see my airflow rise accordingly and find the missing 20bhp ?
    I have actually noticed a slight whistle when under boost which I always thought was the tinny downpipe but now I am suspicious that it may indeed be a leak around that area.
    Could it be a weak actuator or is it more likely to be a leak ? Does anyone have a log file they can post from a car known to be running well that I can take a look at ? On the VCDS log how close to the requested value will the actual get ? are we talking within a few psi or almost bang on ?
    www.badger5.co.uk
    May 2004
    nr Glos
    3,851
    Post Thanks / Like
    actuator test is disconnect n75 electrically and go see what boost it holds.. Typically 5psi rising to 8psi on some as a guide
    bill@badger5.co.uk
    Dec 2011
    258
    Post Thanks / Like
    Cheers,
    didnt get a chance to look last night but hopefully will get time either today or failing that it will be the weekend.
    Its just too cold outside lol !
  1. How to log with VAG COM.
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2012, 12:44
  2. Vag Com ... Things to log ( groups not just one thing )
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2011, 17:31
  3. 1.9 tdi AFN code 110 vag-com log
    By fARQUARE in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2010, 19:43
  4. help with vag-com log
    By vinceemmery in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th August 2009, 17:45
  5. Great instructions for how to log using Vag-Com
    By themanthatcan in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2008, 21:05
