Forge MotorsportBadger5
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By s3gazz
Thread: What IAT'S do u get on liquid gauge
    Aug 2010
    bradford
    723
    Post Thanks / Like
    Well I'm wondering what IAT'S people are getting looked at mine the other day on my liquid gauge and after sat in traffic for 15 mins and car running for about 25 mins the most it went to and has never been above is 30 when I put my foot down it drops to about 9 is that any good.
    I'm running 3 intercoolers too wich I did want to get the toyo intercooler soon but been told that is quite good
    Silver s3 amk 2001, hybrid turbo, silicone, forge 007p, HID kit, big intercooler, jetex filter, badger 5 3" tip, boost gauge, n249 bypass, xs 3" downpipe & de-cat, privae plate s333 gln, liquid gauge, quick shifter, LCR brembo's, oil catch can, r32 arb, AGU ported and polished Head, genesis 550cc injectors, Milltek non res, kw v2 Coilovers, I.E con rods, s3dave tie arms
    coming up
    xs manifold
    FOR SALE
    standered cat back exhaurst
    s3 side mount intercoolers
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    5,018
    Post Thanks / Like
    on my daily I get up to 60-61 degree IAT's on the standard single side mount intercooler! absolutely mental.
    Not logged the track car yet on the welly cooler.
    9 degree IAT's on boost is pretty awesome, although I'd hate to see what the pressure drop would be with 3 cores in the system :S
    Prawns 291bhp R-Tech tuned Track Car
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    820
    Post Thanks / Like
    This evening I was seeing temps ranging from 12 to -1 but I've got a fairly large cooler and a bit of meth to help it along the way
    BAM S3, MTM K26 With External Gate, Hayward & Scott Custom Downpipe & Decat, Custom 3" TIP & Jetex, Lots of Silicon & Alloy Piping, Supersize DV, Southbend Clutch & Single Mass Flywheel, WMI, Porsche 6 Pots, 300mm Rears, AH Fabs V2 FMIC and to much more to list
    Power & Torque 335bhp 285ftlb
    My Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  5. Likes Westy liked this post
  6. #4
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    820
    Post Thanks / Like
    Forgot to say that when I was running the ah Fabs v1 cooler I was always seeing temps on boost of 50-60 degrees plus but since going to a more free-er flowing cooler the temps dropped through the floor
    My Build Thread
  7. #5
    Aug 2010
    bradford
    723
    Post Thanks / Like
    Thanks all stacey them Readings are mental with the wmi and v2 ah intercooler.
    Prawn god Them readings are high hot hot hot lol was going to get the welly cooler too but westy don't get better readings than me as we stand now so no point going warmer lol v2 ah tho sounds great might have to invest in that one And I no what your saying about the pressure drop done a test with liquid gauge and pod gauge plumbed in to dv and had 1 psi drop from the turbo charge pipe all the way around and s3 dave got same set up and he had no drop at all hard to believe
    Reesy likes this.
    coming up
    xs manifold
    FOR SALE
  8. #6
    Prawn's Avatar
    Dec 2006
    Basingstoke
    5,018
    Post Thanks / Like
    A mechanical guage plumbed into the dv won't show you pressure drop though mate, you need a source that's PRE intercooler, so the n75 is your only real option.
    The dv line is fed from your inlet manifold, so should rad almost exactly the same as your liquid!
  9. #7
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    12,808
    Post Thanks / Like
    Quote Originally Posted by s3gazz View Post
    I think you're getting mixed up when I was running a small fmic before the Wellycooler! I logged AITs last week and saw lows of 5 degrees without my WMI running
    FOR SALE
    - BAM connecting rods
    - 1.8T cams
    - K03 OEM Exhaust Mani from AEB head
    - 1.8T Water pump, only a year old. (5K miles)
    - OEM S3 back box complete with both bits of trim
  10. #8
    Prawn's Avatar
    Dec 2006
    Basingstoke
    5,018
    Post Thanks / Like
    that's pretty nuts guys. can't wait to see what my IAT's are on the welly cooler with the hybrid at low boost.
    The manifold certainly likes to get bloody hot already! Scarily so infact.
  11. #9
    Aug 2010
    bradford
    723
    Post Thanks / Like
    Thank lads ye westy probably is the old intercooler then might have to get one then ha.
    God nose about the test then lol but wonder what presure drop I'll have roughtly and what it couseies
    Prawn is the xs manifold good then mate
    coming up
    xs manifold
    FOR SALE
  1. liquid gauge adaptor
    By s3schofield in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2011, 14:47
  2. Scan Gauge / Liquid Gauge.. Can it display the Post I/C temp ??
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2011, 21:56
  3. Liquid Gauge for my S3 - Should i?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2010, 11:46
  4. S3 Liquid Gauge
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2010, 15:05
  5. Liquid gauge
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 23:10
