KowalskiJBS
    Sep 2010
    Devon
    281
    Post Thanks / Like
    VCDS Legends...Anybody know what these codes are because ross-tech doesn't....
    As title suggests....
    I'm still having trouble with a dodgy awd system, its snowing so not been loads of fun! I scanned the car again today and it came up with:
    01324 control module for AWD J492 no communication-intermitant
    01312 Powertrain Data Bus faulty-intermitant
    If I clear the codes awd works perfectly for a while then stops suddenly, not good. I've got a haldex controller reserved for me which I'll get on wednesday but just wondered if anybody had any other suggestions as to what these codes might mean apart from the controller? I've had a good search on here and via google but found nothing solid apart from 'go buy a whole diff/haldex' which doesn't seen very constructive or econonically sensible!!!
    Russ
    Stage 0.25 S3, as Audi intended it, except with a little wear and tear. And a few extras
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,516
    Post Thanks / Like
    Check the earth strap and wiring plug for the Haldex first... earth strap breaks and wiring plug corrodes...
    There is a thread in the stickies...
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    s3dave's Avatar
    mediator
    west yorks
    6,953
    Post Thanks / Like
    Quote Originally Posted by 16Klappe View Post
    And anyway, less of the thinking because I'm ALWAYS right!
    Sep 2010
    Devon
    281
    Post Thanks / Like
    Thanks fella's! I read that in the stickies, my plugs/connectors are all good, much better than I expected them to be. All my earth straps around the engine bay and battery are all good and being a pre-facelift I can't find one coming off the diff or where Bill suggests but I think that only applies to facelift models.
    Dave.. Cheers I've read that one and a few others as well, there just always seems to be a different outcome...pre-charge pump or controller or haldex clutch, everyone seems to have a different problem which is why I thought I'd see if anyone on here had any experience of this?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,516
    Post Thanks / Like
    Quote Originally Posted by slowcoach3 View Post
    Pretty sure there is an earth strap on all haldex cars... if its not there that could be your problem... no communication suggests no power...
    <tuffty/>
    My build thread...
    Sep 2010
    Devon
    281
    Post Thanks / Like
    I know on facelift models it is on the near side and relatively obvious when you look up at it from a ramp but I know quite a lot of people struggle to find them on pre-facelift cars. It does seem like the answer in theory but its odd that it only normally works after fault clearing with vcds.....I can always communicate with the haldex ecu using vcds so that would suggest there is power? Bloody thing!!!
  1. Checked Ross tech and it's not on there ? 17947
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2011, 22:30
  2. wiki.ross-tech?
    By Khufu in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st February 2011, 05:18
  3. Help with error that isn't on the Ross-Tech wiki!
    By Westy in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th July 2010, 16:12
  4. Which ross-tech VAG-COM software for an 8L?
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2007, 17:28
