just wondering if anyone has already fitted one what side of the N75 valve to fit it?
had one on then removed it
Stroked 2067cc (2.1) S3. AEB Ported & Gas flowed head, Piper cams, Valve + Spring kit, Big intercooler, IE rods, JE Pistons, CP rings, Milltek, GTX3076r Turbo, External Gated, 870cc injectors, Twin pumps, Wide Band conversion, ALD Custom inlet with R32 T/B, MkV TSI Coilpacks conversion, Fluidampr pulley, 4kg Billet steel flywheel, 4 paddle clutch, Coilovers, R32 rear ARB, Blue Haldex, 350mm 6 pots fronts & 330mm rears. Going for 550bhp, 600bhp with new injectors and more boost
I've got an ebc plumbed into the track car.
The best way to plumb it in is in parallel to the N75 not in series.
T off before and after the N75 to use the boost controller to cap boost spikes.
if you want it to increase boost at all, forget it.
Prawns 291bhp R-Tech tuned Track Car
The question one needs to ask is why do you want/feel the need to fit a boost controller in the first place...
MBC's are pretty crappy to use on thier own as part throttle boost control is fairly non existent... only time you may need to use an MBC in parallel with the N75 is to control boost spikes or if in rare cases you have a pikey map that has all the boost request in the world and you are trying to prevent your engine from eating itself without going to the expense of a map thats better suited
EBC's are ok but suffer the same issues under part throttle but can work well (in Prawns case for example) when the mapping is sorted to take advantage of it... it will allow him to control the boost up to its maximum request which is useful on a track car like his...
Using one to get more boost without having a map will just end in limp mode at best....
<tuffty/>
Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
My build thread...
sorry for the late reply but thanks for the info, the reason i was looking to fitting it was my friend just upgraded to an electronic controler and gave me his old manual one and im not the sort of person that turns down new shiny bits! so thought id give it a go if it gives a little extra boost. Basically your saying its not worth bothering with then?
I wouldn't bother fitting one to try and get more boost no....
<tuffty/>
My build thread...
Sorry matey, but as said earlier, boost controllers should only ever be used to contain or control the boost level for which the car is mapped.
Fitting one to gain boost is a big no no I'm afraid.
