DTUKAWEsome GTI
Results 1 to 15 of 15
    Aug 2011
    Post Thanks / Like
    Hiss on cold start up??
    Hi guys, i've got a a3 quattro and ive noticed something strange with my car. When starting up the car cold it'l rev at 1,200 rpm for a few minutes and then settle slowly down to about 800rpm. Now not sure if this is normal but it's always been like that.
    However now ive noticed that just before it starts to drop there a very distinctive hiss. Is this normal??
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    12,808
    Post Thanks / Like
    Revs will always be higher on cold start and they will drop as the engine warms but yours might be a bit high.
    If I was you I'd stick your head under the bonnet and see if you can pin point the hiss as it sounds like you might have a split hose somewhere.
    FOR SALE
    - BAM connecting rods
    - 1.8T cams
    - K03 OEM Exhaust Mani from AEB head
    - 1.8T Water pump, only a year old. (5K miles)
    - OEM S3 back box complete with both bits of trim
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,516
    Post Thanks / Like
    Its most likely the SAI... if its hissing then it could be that the vacuum pipe has been disconected... yours had an N249 bypass or something?
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,499
    Post Thanks / Like
    Do you have the aircon on when starting up? If my air cons on when i first start the car, you get a whining/hissing noise.
    Aug 2011
    Post Thanks / Like
    Just stuck my head under the bonnet (luckily its cold outside so it didnt take long for the engine to get cold)
    Theres definitely a small click before the hiss, almost like a switch clicking by the battery. The hiss it self is coming from the front of the car below the throttle body. Not sure if it makes a difference but i have the Electronic throttle on mine.
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    772
    Post Thanks / Like
    Sound like the a/c fan.. see if it does it with the climate set to Econ.
    Aug 2011
    Post Thanks / Like
    The air conditioning/heater was off at the time.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,516
    Post Thanks / Like
    SAI....
    <tuffty/>
    My build thread...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,516
    Post Thanks / Like
    ...or a vacuum leak from the PCV...
    <tuffty/>
    My build thread...
    Aug 2011
    Post Thanks / Like
    any ideas on repairs costs etc.
    and how it would affect my cars performance
    QuattroRich's Avatar
    Quattro Formaggio
    Jun 2011
    Oxford
    30
    Post Thanks / Like
    Quote Originally Posted by walla View Post
    I have an A3 quattro and have this hissing sound coming from the same place. Only seems to have come about now the cold weather has set in and disappears once the engine has warmed up after a couple of minutes.
    Can this problem be solved easily?
    Reesy's Avatar
    Not too low but still too slow
    East Sussex
    2,572
    Post Thanks / Like
    It's the SAI as tuffty said. My 2 tqs' have both done/do this...
    Quattro Formaggio
    Jun 2011
    Oxford
    30
    Post Thanks / Like
    Cheers Reesy, will look into it
    Reesy's Avatar
    East Sussex
    2,572
    Post Thanks / Like
    Quote Originally Posted by QuattroRich View Post
    Shouldn't need to mate, if it makes a noise and then cuts off as the revs drop, its more then likely working fine. Mainly happens when car and ambient temp are cold.
    Quattro Formaggio
    Jun 2011
    Oxford
    30
    Post Thanks / Like
    I was hoping that it was just due to outside temp. Cheers fella
  1. Cold Start noise? Anyone have this?
    By 330_2_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2010, 10:54
  2. New S4 - Cold Start
    By pherbert in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 13th April 2010, 22:44
  3. Noisy start-up from cold start???
    By linners in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2010, 15:47
  4. Noise on cold start up
    By Wilkinson in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 24th November 2009, 19:43
  5. S3 Cold Start Problem
    By squale in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2008, 01:15
