DTUKEM Tuning
Results 1 to 7 of 7
    Dec 2011
    10
    Post Thanks / Like
    Audi S3 temp above 90
    Hello all, i had a strange issue the other day after giving the car a boot to catch the lights, after this the temp gauge went up to 95ish and stayed there, put the heaters on was blowing hot, temp stayed up but didnt go any higher, stopped at petrol station and after refuelling the car and restarting the temp was back at 90 and has been fine ever since.
    For the record i changed my temp sensor and thermostat 4 months ago, car is standard apart from forge 007 and a DNA tuning map.
    I was concerned it could be headgasket but all seems ok, no funny colour in oil filler, heaters blow hot etc
    Has anyone had any similar issues?
    Thanks in advance for any help
    Jul 2007
    490
    Post Thanks / Like
    If it happens again I would suspect the waterpump but its probably a oneof
    Dec 2011
    10
    Post Thanks / Like
    Ah i did wonder about the waterpump, hopefully a one off though. Will be changing pump, belt etc soon anyway as im not sure if pump has been done, 86k
    Thanks for the reply
    bez101's Avatar
    Jul 2008
    3,400
    Post Thanks / Like
    if its never had a belt change chances are the pumps never been done
    id say its about ready at 86k
    Dec 2011
    10
    Post Thanks / Like
    The belt has been done in the service history but nothing to say about pump, will do them both for peace of mind
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Had you been sitting in traffic for a while?
    The guage has a buffer which means it doesnt move past 90 until the temperature exceeds ~100c
    If you'd been sat in traffic its likely the temperature was up around 98-99c anyway, and at a guess you've booted it thru a light then slowed down again resulting in a short spike in temperature over 100c which has brought the guage up?
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Dec 2011
    10
    Post Thanks / Like
    Thats exactly what happened aragorn, but i still thought it strange as i didnt think these gauges moved once at 90 unless there was something seriously wrong.
  1. Temp Guage not working - coolant temp sensor changed... now what?
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2012, 19:10
  2. Audi A4 Temp readout correction
    By A3 Craig in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th December 2011, 12:24
  3. Audi Temp Sensor
    By tonybolony in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2010, 11:45
  4. JUST FITTED AUDI A3 1.8T TEMP SENDER
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2010, 23:42
  5. Oil temp/engine temp
    By smitch in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th December 2006, 07:26
