is it possible to clock a Ko4 turbo compressor housing so i can retain my boost pipes location on my a3?
wanted:
k04 turbo, Saab 360cc injectors, Vr6 maf
FOR SALE:
Complete dog bone mount with powerflex bush (Check my build thread for picture)
My progress thread
Not really, for 2 reasons. 1st if you just clock it to get past the manifold I points straight at the firewall and there's room to get the boost pipe on. 2nd the actuator won't fit as the locating holes are out. Best and only way is to mate the outlet of a k03/s to the k04 compressor housing. Cut and weld.
Hope this helps
Ps just seen you after a k04 and injectors , I have both for sale if it's any help
K04 turbo and mani sits further up and further to the gearbox end than the K03... it also sits closer to the back of the engine...
It would be easier to fabricate the charge pipe than modify the turbo comp housing... see Prawns thread as he has fitted a K04 to his A3 and has sorted the pipe work...
<tuffty/>
Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
My build thread...
ok cheers lads
wanted:
FOR SALE:
My progress thread
what intercooler pipework do you have at the moment? is it standard AGU charge pipe stuff, or an aftermarket front mount?
if it's an aftermarket kit, your best bet it to mount up the ko4, put your ko3 pipework in place, and just work out what combination of bends you'd need to join the two together.
I recently fitted a ko4 to my AGU track car, and eventually decided to do away with my old intercooler setup totally and just come up with my own pipe route, wasn't hard realy, and the results are great.
Prawns 291bhp R-Tech tuned Track Car
Hi prawn yeh its all standard at the minute. How did you go about fitting the 3inch tip. Or as tuffty says the mani sits further up so does it clear everything alright.
Wow my maddness of orange rocker cover has started a craze lol
liking the xs manifold, may i ask what downpipe, exhaust you have used. Cheers SY
wanted:
FOR SALE:
My progress thread
what diameter pipe work have you used prawn.
wanted:
FOR SALE:
My progress thread
badger 5 80mm TIP fits as it's a ko4 turbo, there's a slight interface with the gear cables, but it's not too bad.
manifold is indeed XS power, as is the downpipe, very happy with it all so far.
Pipework on mine is 63mm the whole way from the turbo to the throttle body.
Didn't realise you'd painted your rocker cover orange, mine's orange as it matches my colour scheme
Both of you wussed out on the orange:
For Sale: Breaking B5 A4 - Check my eBay page!
Wanted: Facelift A4 Front Bumper with Headlight Washers.
2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
1997 S4 - PPC £999 Challenge Track Car Build starting soon!
Audi V8 powered Land Rover Defender build in progress.
wanted:
FOR SALE:
My progress thread
[QUOTE=Prawn;1479095]badger 5 80mm TIP fits as it's a ko4 turbo, there's a slight interface with the gear cables, but it's not too bad.
Didn't realise you'd painted your rocker cover orange, mine's orange as it matches my colour scheme=QUOTE]
Ok cheers for that.
wanted:
FOR SALE:
My progress thread
Been there, done that!
Moved on :P
