Hi everyone,
I have been having intermittent (more often than not) boost issues where the boost will drop out several times through the rev range. Since its not all the time, for example; yesterday it was fine for a good 15miles straight untill I pulled over to go in a shop, came back out, drove off and the issue came back again, I'm wondering if this issue could be electical? I have insulated all the split wires on the coil pack loom (since it fixed Rogo's problem) and that didnt fix it. Also, if it was the n75 valve, could I just unplug it and see if that makes much of a difference or would the only way to check it be to replace the n75 unit?
Took it into Audi in Derby who did the coil pack recall and they checked it over, they basically came back to me saying they wanted £130 p/h for diagnostics, but they also said it could be the turbo... which im guessing will be any dealers answer.. chuck a new unit at it and see if it fixes it?
I've replaced the old cracked plastic DV with a forge 007p, checked over the pipework for visual splits and cant find any...
Thanks a lot for your time
LinkBack URL
About LinkBacks
AUDI A4 TQS
My Build thread
