EM TuningJMB Retrofits
Results 1 to 15 of 15
    Nov 2010
    North Wales
    130
    central locking and electric windows please
    central lockin and fob and my electric windows are not workin
    the iluminated switches for the windows does not iluminate any more
    door lock or de lock button on door card orr on key does not work
    but y electric mirrors and interior lights work
    its not a fuse
    can anyone help please
    27,033
    Sounds like convenience module to me, is it just the drivers door with issues mainly as you could check the loom that passes from the pillar to the door, maybe some wires have got damaged or broken.
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    oe central locking pump in boot
    27,033
    That is the conv module aswell.
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Can you open windows???
    But definitely this is a central locking pump. It get wet. Remove it and check before is to late.
    Currently not in the country
    Nov 2010
    North Wales
    130
    hmm i know the pumps bit wet ha
    both windows dont work or fob,,,, right ill take the pump out for inspection
    as for the convinience module i have no idea where that is as its not under the drivers footwell with the fuse box and realys
    thanks rhys
    27,033
    The pump is the conv module.
    Nov 2010
    North Wales
    130
    ahhh,,, doh ,, so simply take it out the boot ect
    very strange that things go to pot cause of one thing,,, ill have look tonight
    Sep 2011
    tiverton
    337
    yeah the convenience module is the same part as the pump, not in passenger footwell, thats on passat, their a pain in the arse, mine has gone twice, theres a few common problems with them, yours doesnt sound like the impeller, more like a problem on the circuit board to me. if you replace the whole box be careful to match the part number EXACTLY, and you will still need to get it reprogrammed 99 times out of 100
    Nov 2010
    North Wales
    130
    i really hate not having windows i can open
    wackd the pup of earlier had look lookd ok
    have a pump i cd try fit of an a4 see if its tht, but ill be buying vagcom soon enough so i can diagnose the problem
    also if it helps the door light doesnt come on now when doors open, but the light will wrk if u turn it on manualy
    Dec 2011
    Basingstoke
    84
    Sounds like the convenience module to me (the PCB housed in the central locking pump)... when you disconnect it, the central locking stops working and so do the windows, don't expect your car to be alarmed either!
    Nov 2010
    North Wales
    130
    bloody wierd :/ anyway i can test the module , or is it posible to have windows without the pump?
    thanks
    27,033
    You need vcds bottom line before you do anything else.
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Quote Originally Posted by 20v-turbo View Post
    ...or is it posible to have windows without the pump?
    thanks
    No m8 you have to replace that pump. Check the part number and then I can tell what other pump you can fit on.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    Well no, you can have windows without the pump, you just need to know what your doing.
    The pump sends a 12v signal down a particular wire to tell the window regulators they are allowed to operate. Simply splice this wire to 12v and the windows work fine. I know this because i've ditched the central locking system in my track car, and wanted the drivers window to still operate, so i figured out the wires and made it work.
    Its a bit pointless for a normal road car though, just replace the central locking pump.
    You could probably stick a temporary jumper wire in while you sort out another pump though. You want to put an ignition live onto pin A11 (red/black) at the locking pump, the live can be sourced from pin A8 (Black/Blue). Pump unplugged ofcourse.
    TD5 Land Rover Defender build
  1. Central locking and windows not working
    By betamike25 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2012, 16:20
  2. 2000i A3 1.6 Sport - Central Locking Pump / Electric Windows fault
    By msowerby in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 20:28
  3. Central locking & windows
    By Rikster23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2009, 21:43
  4. Central locking along with all electric windows!
    By mitalm in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2008, 23:53
  5. A4 (B6) remote locking/electric windows
    By trevaudi in forum General Technical / How To
    Last Post: 28th November 2007, 08:42
