AH FabricationsJMB Retrofits
Results 1 to 14 of 14
    S3 Paul's Avatar
    Oct 2006
    2,764
    Boost increase ! Due to the weather conditions??
    The other day i had been "playing" under the bonnet also had to reset home possition of the sunroof so included taking the battery off,
    The wierd part of this was when i was out driving about an hour after... i did about 20 miles then as the roads cleared "pushed on a little " the car felt great, I checked the boost gauge and... it normaly spikes at about 24 psi then holds 22 through to the limit,
    With the AFR gauge reading between 11.7 and 12.0 under full boost ,
    This time i was seeing 28 psi dropping to 25 but with the same AFR readings.
    The weather was very misty and showing 4.5 degree on the gauge .
    Is this down the the colder dense air? or something down to the fact i reset the ECU?
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Could be both mate, disconnecting the battery, resets the ecu's perimeters so it starts to learn again etc from what i understand.
    See how it drives for a while mate and see if it maintains the same boost!
    S3 Paul's Avatar
    Oct 2006
    2,764
    The boost still reachs the same kind of levels.
    the temp was 5 degree outside today,
    Im using Tesco Mommentum fuel but thats about on par with V power isnt it?
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Both 99 based mate so yes.
    Colder air does help, denser so more oxygen so better burn.
    You logged it with vag com?
    S3 Paul's Avatar
    Oct 2006
    2,764
    Nah. was on a blast over to see my daughter this first happened, then today on my way home from work i tried nailing it ...
    I will be out and about doing a few miles either tomorrow night or saturday. Vag com at the ready
    Noggy Blue 2001 S3
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,556
    In general, turbo cars are usually quicker in cold weather than warm.
    Customboy's Avatar
    Jan 2012
    SE London
    836
    If its nice cool misty weather car will fly I know mine does when I go to work early in the cold morning car just eats the road!!
    S3 Paul's Avatar
    Oct 2006
    2,764
    My only worry is the AFR,
    People i know round here seem to think the 12 is too lean?
    Noggy Blue 2001 S3
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    I had an amazing thought the other day, which will work for me and S3 owners.
    My car had headlight washers so I have got an additional outlet for the washer bottle, and because I have my rear wash/wipe removed I have a pipe and pump for that too. My plan is to make an FMIC sprayer using the remaining pipes and setup and then just filling my washer bottle with water and using it that way. I was planning on running it so that it comes on with the rear wash, so on a power run or if I need boost on a hot day I can just bang it out and get cold/wet day performance.
    I'll mock it up, make a proper profesh job of it and do a how to thread. I'm off this week so it is my task for the week
    I quite often say I'm going to do things.
    Then never do them.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yes its been talked about before , and will certainly help....
    S3 Paul's Avatar
    Oct 2006
    2,764
    I managed to blag a pair of washer jets and a washer pump from a bmw parts man i know... i bought the pipe but never made it round to fitting
    Noggy Blue 2001 S3
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,372
    Quote Originally Posted by S3 Paul View Post
    12's on boost are fine. Ignore those telling you otherwise
    S3 Paul's Avatar
    Oct 2006
    2,764
    The reason i asked on here is that they are general tuners ( civic and corsa turbo cars) so i was unsure if they knew best about my set up
    Noggy Blue 2001 S3
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,380
    The boost would typically DROP in cold weather. Or perhaps more correctly increase in warm weather to compensate for the reduced charge.
    12:1 AFR is fine.
    28 psi seems somewhat dangerous to me.
    TD5 Land Rover Defender build
  1. EM Tuning's terms and conditions
    By t8ups in forum EM Tuning
    Last Post: 3rd October 2011, 20:18
  2. S3 drives like a pig at speed in ice/snowy conditions??
    By Rob_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2010, 22:10
  3. Replies: 71
    Last Post: 4th December 2009, 16:22
  4. Boost increase
    By TorqueTerrorist in forum Diesel forum
    Last Post: 20th August 2009, 21:25
