JMB RetrofitsEM Tuning
    imported_mustwin1
    Camshaft Position Sensor
    Morning chaps.
    I’ll be well chuffed if any of you guys can come up with the answer to this problem. I’ve got a 99TQS and its running lumpy as anything, hard to start etc etc. Now, on the diagnostics machine it’s coming up with the following code:- PO341 (Camshaft Position Sensor, no plausible signal), I have changed the sensor but still the engine is running in safe mode, and the same fault code is still coming up. What gives?
    Any help most appreciated [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Mar
    DaveACQ20v's Avatar
    Nov 2004
    UK south west
    429
    Re: Camshaft Position Sensor
    disconnect your battery for half an hour [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I'm assuming you have cleared the fault code after replacing the sensor?
    If you have and you are still getting the same error then the problem will be in the wiring.
    imported_mustwin1
    Thanks chaps. I've tried all of the normal, but no go. Any other ideas anyone?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    So have to done a continuity test between the sensor plug to the ECU?
    imported_mustwin1
    Well just spoken to AMD and they have said that they have had a few similar problems with 5+ year old A3's. Apprantly the heat from the turbo can cause the wiring to crack, not always fully, but partly crack. I will check it out and get back to you with my findings.
    Cheers again
    Mar
