Monster MotorsportEM Tuning
Results 1 to 9 of 9
    A3tell's Avatar
    Jun 2009
    essex
    239
    urgent facelift headlight and bulb question
    i know this is covered but am at the point of fitting my facelift headlights, is it the middle of the 3 that my HID bulb goes??
    if so what bulb goes in the big end holder as my h4 obviously doesnt fit!!! thanks for any help you can give!!
    A3tell's Avatar
    Jun 2009
    essex
    239
    also am i right in thinking that they will require H1 fitment HIDs, as i just found out that the middle light is for hi beam, but the H7 doesnt fit in them!!!
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    H1 is dipped beam, for facelifts at least.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    The HID will go in the inner projector. Take the ring off the h4 and it will fit the beam.
    A3tell's Avatar
    Jun 2009
    essex
    239
    ok, i will try that, but then how do i wire up another H7 bulb for the middle main beam????? as the existing will be wired into the existing HID!!! getting a little confused now!!!
    Aug 2010
    45
    Here you go dude, exact same problem i had last week. I had the lights working withing a couple of days after following the link and getting the parts needed
    Headlight Conversion
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    You have 2 holders.. The projector one is the h7 HID, That should fit. Are you using the facelift loom inside the lamp or have you swapped it for your own?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,504
    Follow this Audifans.net: You are using an invalid IP hope it helps.
    A3tell's Avatar
    Jun 2009
    essex
    239
    thats the guide i used to fit mine..... i did the same thing, with the loom, but my h7 HIDs didnt fit where the dip beam should go. (in the projector) it is a H1 fittment!! now i am thinking that i need a loom made up because just for now i managed to fit my HIDs in the projector slot, they come on ok but my dash says my main beam is on!!! i am proper confused with it all!! i am not a novice by any means, but this is got me baffled!!
  1. Daft Headlight Bulb Question.
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2011, 18:25
  2. Urgent Headlight help needed please
    By Slinger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th October 2010, 12:56
  3. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
  4. Headlight bulb
    By sniperlover in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th December 2007, 23:03
  5. facelift headlight- bulb arrangement
    By emerylloyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2007, 14:29
