AH FabricationsEM Tuning
Results 1 to 28 of 28
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Just recieved my vent gauge pod...help please
    So just had my vet pod through the post, having abit of trouble fitting my 52mm gauge inside. It does say some sanding down may be required etc. but seriously how much do I need to take off? Worried I might make the outer lip to thin. The bit where the gauge face sits.
    Also just wondering what wire do I connect the positive too from the gauge? And where's best to earth it?
    Will post some pics when it's all finished. Just need a little bit of help before I do it all tomorrow.
    I no there are two places to t off, the fpr line or dv to Inlet hose. Buts what's best to t off of? Any pics of peoples installs I the engine bay would be a great help.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    positive is up to you. i wired mine into one of the fuses. so when the ign turns on so does the gauges.
    or you could wire it into one of the backlight lights e.g cig lighter light so it only lights up when you turn the lights on
    earth. any bare metal sureface, there is a earth point behind the drivers side of the dash. just use a ring crimp and join onto the earth bolt
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Oct 2008
    Glasgow
    430
    Hi james,
    Just take a little off at a time until you have a snug fit. Im sure you wont cause any damage.
    The pdf file i sent to you will show you how to install the gauge and the pictures show some good shots of the engine. I prefer to T off of the FPR.
    Hope installation goes well.
    Eddie
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Yeah still have the file Eddie, it's given me quite a good idea about the t-piece and stuff. Just wondering about the wiring as the PDF file is for a4/s4? I have decided I'm going to use the headlight switch loom. Just wondering which colour wire to bridge into. Do have a multi metre to hand but thought someone might of been to just tell me lol. Lazy I suppose.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Is there any way to see if the gauge lights up before I fit it tomorrow? Just got it fitting in the pod nice and snug.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    a 9V battery will light it up
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    nice one, had a feeling it would be something as simple as that
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    DV line for the t piece
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Why do you say dv line over for line?
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    I've seen this mentioned for people doing N429 bypasses as well. You get the same pressure reading from the DV and FPR line. However if you have a boost leak at your t piece (3 new potential holes) and you have plumbed it in to your FPR then you will under fuel and run lean which isn't good.
    You have done the N249 bypass so you could plumb is straight into the top of the DV
    Obviously if you guarantee that you have a perfect seal at your T piece then it makes no odds
    Alex S3 AMK
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Ok so just plumbed it all in. Lights up so wiring is good. Problem is...I'm not getting a reading? I got a tpiece at the dv end of the inlet to dv hose. Then routed from there along engine bat down through main harness part and into the back of the gauge. Not sure why I have no reading? Obviously something really isn't right
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Is the vac pipe properly attached at the back of the boost gauge?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    have you kinked the pipe ?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    It was before I placed the vent pod back in its place, weather it's come off during fitment I don't no. Was a pretty tight fit onto the rear nipple though. I will double check in a minute. The vent pod is in properly snug too. Will be fun lol. Is there anything else I can check? I checked all the Jose I can see for splits and there's nothing. Tpiece is all good too
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Might be kinked it the vent. I'll Check that too.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Was kinked behind the vent. Just took it out for a drive as battery went flat from door being open all day.
    When sat in neutral at idle it's sits at about 16inHg. And it peaks at about 21ish? That sound about right?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    around 20HG is about right. the PSI would depend on your mods and maps
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Should be around 20 mark.
    21psi if mapped sounds about right as well mate.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    That's a relief then. Yeah it's mapped, no idea what too just have a reciept for a cc phase 1.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Where did you end up taking the live from?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I used the live and negative from the vent light. Can now be dimmed along with other interior lights
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    i would personally get a better gauge.
    cheap thing off ebay ?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Well off eBay but wasn't the cheapest. What's wrong with it?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    i've used gauge in the past (with the same brand logo) which was cheap from ebay less then £15, gave incorrect read outs
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Payed about 28 for that one. I do understand its probably not as good as some others. Got a stack gauge on the bday list for next month. Should go with interior a bit better too. Was going to mask it up and spray silver face black but cba.
    Oct 2008
    Glasgow
    430
    nice one that you managed to fit it. I like how you took the live feed from the vent light.
    Thats very cheap for a gauge, im fussy so wouldnt go that route as its not something that looks suited to the interior, for me podi gauges are great quality and match the interior perfectly plus once fitted they look stock (as if fitted from factory) If you have the money you definetly should go for the one i suggested.
  28. #27
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Cheers Eddie, that gauge was like £135 though which is too much for me to spend on a gauge. I believe it's most likely worth the money, I just cant afford it myself.
  29. #28
    Suck.Squeeze.Bang.Blow
    Jul 2011
    Madchester
    227
    This is my install. The pod did take a fair bit of sanding out but managed eventually
    It's a newsouth performance boost gauge from swg Motorsport.
    At night (looks quite light in comparison to the clocks but it's just the picture, is a very close match to the clock colours in real life)
    And during the day
  1. Air Vent Gauge Pod
    By MarkTweedley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th October 2011, 13:55
  2. Vent pod for 52mm boost gauge.
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2011, 22:19
  3. Vent Gauge Pod DIY
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2010, 21:08
  4. Air vent gauge pod
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2009, 17:24
  5. boost gauge vent pod
    By mastayoda in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2007, 13:16
