Chris NottVolks Autos
    Jul 2005
    Hertfordshire
    Hissing noise when locking??!?!
    Hi guys, this is my first post and its a problem!
    When i go to lock the car with the remote on my 02 s3, there is a hissing noise that seems to have come from the door handle. It only lasts about 5 seconds and then goes off. Has anyone else had this problem? If so, how is it fixed?
    Cheers guys,
    Adam
    imported_gek
    Re: Hissing noise when locking??!?!
    The central locking is controlled using air. Blow to open, suck to lock.
    What you could be hearing is escaping air due to a hole in the pipe to the lock.
    Does it still open/close ok but maybe take a little longer than the other door?
    As to how to fix it, it all depends where the leak is [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Jul 2005
    Hertfordshire
    It sounds as though its coming from the door handle itself. How hard is it to get to the pipe?
