Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    Jan 2012
    2001 A3 sub wiring help
    Hi
    I have a sub from a 2001 A3 which i am fittng into my Golf but i need a diagram or help identifying which wires go where?
    I have some pics but i am not sure how to attach them here.
    Here are the wire colours / pin numbers in connector
    1, Black (Larger diameter)
    2, Back
    3, Red
    4, Red (Larger diameter)
    5, Green
    6, Green
    7, Yellow
    8, Yellow
    9, Blue
    10, Brown
    Many thanks... Andy
    Jun 2003
    World of my own
    9,813
    Alex Turner
    Jan 2012
    Hi Andymac
    That is very helpful but i do have a issue.
    On your loom plug pin 1 is live and pin 4 is ground.
    On my sub side plug pin 1 is black and pin 4 is red.
    I normal electrics red is live and black is ground. Do you know if it is different in the audi?
    I do understand that wire colours change from loom side of plug and component side, but when matching up pin numbers i noticed the above issue.
    Andy.
    Jan 2012
    Andymac
    Just looked at your photo bucket pictures and the sub i have got is the same as picture 120. It as a single sub on a silver metal/alloy mounting front plate.
    Andy
    Jun 2003
    World of my own
    9,813
    Sorry the pic is the socket side, i.e. the loom side, so you need to mirror this to get the male sub side, which is why everything is arse about face
    Alex Turner
    Jan 2012
    Quote Originally Posted by AndyMac View Post
    I undestand its the loom side and i can work out what wires should go where from the pin numbers and the locating section on the socket.
    But is it possible for you to see if
    1. Your loom pin 1 (Fat red/wht) LIVE goes to pin 1 (fat black) on sub?
    2. Your loom pin 4 (Fat brown) GROUND goes to pin 1 (fat red) on sub?
    Sorry to be a pain in the arse. I just want to be sure before i wire it up and power it up.
    Andy.
    Jun 2003
    World of my own
    9,813
    No
    Using your pin numbers
    1, Black (Larger diameter) = ground
    4, Red with white stripe (Larger diameter) = permanent live
    One of us must have the connector upside down, can't remember if I used the pin numbers detailed on the connector, or if there even were any, although looking at the wierd numbering I doubt I would have made that up.
    Alex Turner
    Jan 2012
    Thanks for the info. I will try to work out from the info i have got from you. Here is the pic of my plug showing some of the numbers.
    http://i1153.photobucket.com/albums/...14/IMG_008.jpg
    http://i1153.photobucket.com/albums/...14/IMG_007.jpg
    http://i1153.photobucket.com/albums/...14/IMG_009.jpg
    Thanks again
    Andy.
  1. Wiring
    By moag in forum Satellite Navigation
    Last Post: 10th October 2011, 18:30
  2. Wiring help
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2008, 15:16
  3. is this wiring ok?
    By fenian672000 in forum In-Car Entertainment
    Last Post: 4th March 2007, 23:18
  4. Replies: 3
    Last Post: 2nd April 2006, 19:25
  5. Are pre 2001 door cards the same as >2001 in a 3dr
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2004, 10:12
