Sky InsuranceEM Tuning
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 84
  1. #41
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Nope... its a control valve designed to release pressure in the tank etc... not sure how it all works but it will throw a fault code and a CEL if not coded out...
    Its not a prob to vent the tank to atmos in terms of its operation.. the evap system is there as a combo of pressure release and emissions...
    <tuffty/>
    Stacey has his removed. I'll ask him what he's done to get round the ECL
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #42
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    I've removed mine on the A4. I vented the carbon can out into the wheelarch.
    I do sometimes get a whiff of petrol from inside the car when stationary though, which is a little annoying. Seems worse when the tanks low as well.
    TD5 Land Rover Defender build
  4. #43
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    May just vent it down near the front fog area .
  5. #44
    Westy's Avatar
    Dec 2008
    17,273
    There's already a hole in the arch lining to vent out there but you could extend the hose if you wanted.
    S3 Build Thread
  6. #45
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yeah i know mate, i was just meaning to stop the smell of petty thats all.
  7. #46
    S3 Paul's Avatar
    Oct 2006
    2,764
    Have you changed the lambda yet?
    Checked for air leaks?
    The old school way not just VAGCOM?
    Noggy Blue 2001 S3
  8. #47
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by S3 Paul View Post
    Come on Paul, this is Dani we're talking about! He'll have the lambda changed about August time
    S3 Build Thread
  9. #48
    S3 Paul's Avatar
    Oct 2006
    2,764
    It just seems stupid ( not being nasty) to keep guessing what other things may be causing the problem when you already know of one component the WILL cause the issues he is having thats showing up as being buggered.
    Noggy Blue 2001 S3
  10. #49
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    P**s off westy haha.
    No Paul, im just waiting on a lambda socket to turn up (i know you'd have lent me yours but thought may as well get one and have it to hand).
    So lil update, to westy's surprise.
    Fitted new clutch switch and ripped out the charcoal canister and guess fooking what..........
    NO DIFFERENCE haha.
    So now im just waiting on my socket and ill attempt the lambda, if i cant remove it then ill fit it to the XS DP ready for my shiny new exhaust Friday , can not wait haha.
    Also ill do a full removal guide over the weekend for the charcoal canister, took 5 mins although the existing pipework is still running along the engine bay, i just blocked the TB and TIP off, pikey bodge style .
  11. #50
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Ha cant understand why your still having problems? Iv just changed my maf and that has helped my fuel consuption and idle problem staight away, i cleaned my tb wich stopped my stall and i gave the battrey cables a good clean up, aswel as replacing the little pipes coming off the top of that little silver ufo looking thing to under the inlet mani, and also cleaned up that non return valve that sits in by the engine that goes to the pipe that connects to under the inlet mani(if that makes sense) lol i still have a o2 sensor code but thats due to my cracked exhaust mani, and the car idles high for a few seconds after start up, but i think that just the choke. Anything in that jumbled list that you havent done?
  12. #51
    Westy's Avatar
    Dec 2008
    17,273
    The UFO thing is the FPR (fuel pressure regulator)
    S3 Build Thread
  13. #52
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Nope done the lot.
    Tbh ive god a bad feeling the turbos fooked, the cars making a type of mechincal noise from around the turbo/manifold area, hard to explain, its like when a fan hits its cage kind of.
    When the downpipe and exhaust is off im going to inspect the turbo and manifold and see what condition ther in.
  14. #53
    S3 Paul's Avatar
    Oct 2006
    2,764
    Simply remove the intake pipr "tip" , if the turbo was so fooked that it was hitting its housing there would be massive play and it would feel rough as hell to spin by hand,
    I think you need to do the lambda, If im wrong... i will be suprised but its the only way to know
    Noggy Blue 2001 S3
  15. #54
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Should i start a betting ring to see whats wrong with it, winner takes all.
  16. #55
    Nov 2010
    1,673
    Quote Originally Posted by Westy View Post
    Every days a school day
    As for betting, my money would be on your exhaust mani being cracked and playing buggery to the lambda
  17. #56
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ooh i like that haha.
  18. #57
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    after sending dani some pm's because i had the same problem of idle dropping feeling like the car was going to cut out, iv fix the idle three times, now its come back but its only when there's less than half a tank of fuel left could i be the fuel pump not feeding enough fuel through or would it just cut out if it wasnt getting proper fueling .
    things i have done: tightened everything a million times a checked every thing, replaced and cleaned injectors and FPR, cleaned and reset TB, changed petrol from unleaded to super unleaded, installed a boost gauge reads what the car should be reading, changed all the vac lines for better silicone ones instead of the crappy stuff that was on the car.
  19. #58
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So new lambda sensor fitted along with a new exhaust on friday, and guess what, its still doing it .
    Proper gutted as i thought the lambda sensor would have solved this.
    The strange thing is, the car only does this with the revs when the drive chain has been engaged, i can sit in neutral and rev the ******** out of the car, dip the clutch etc and nothing will happen, as soon as i start driving then itll happen.
    So, could it be clutch related? The car does seem to play up when i touch the clutch, like if in neutral and i dip the clutch, the revs and boost gauge will fluctuate slightly, plus my biting point id through the roof, like foot nearly of the clutch!!!!!
  20. #59
    Mar 2010
    Durham NE
    578
    I would check the turbo,have you pulled the tip off and had a feel,static reving puts no load on the turbo....but as soon as you move and load the turbo it all goes wrong?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  21. #60
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ooh mate you've just reminded me.
    When they did my exhaust friday, they took the charge pipe off, and when i was nosing around i had a look at the charge pipe, it was coated in oil on the in side, thing is ive blanked the pcv system off so only thing it can be is the turbo seals have gone, what you think?
  22. #61
    Mar 2010
    Durham NE
    578
    Good chance the thrust washer is shot,it will cause a loud screech under load,oil usage/smoke ,but really depends on how bad it is,if you pull the tip off and check the side to side play(pull it in and out) if there is plenty then its shot
    James
    Silver Audi 8L S3
  23. #62
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill have to mate, off again in 2 weeks so gonna service the car and ill check while im at it.
    What do you mean you by screech? I do have a funny noise from the engine bay when driving but its hard to explain, like a whering/mechincal/wind blowing, but im unsure if thats down to the engine bay strip been removed so hense more air type noise.
  24. #63
    Mar 2010
    Durham NE
    578
    also difficult to explain lol,um under and boot load the noise will be noticeable,all i can think of its like a amearican cop car following behind you.... im off to find a vid or something lol
    James
    Silver Audi 8L S3
  25. #64
    Mar 2010
    Durham NE
    578
    just to note,as i read your first post,turbo thrust failure would not cause a idle issue,is this the only symptom you have?
    James
    Silver Audi 8L S3
  26. #65
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Kind of.
    Car seems to be intermittent with boost, it usualy boost to 10-11 psi, but if ragged from 1/2nd gear itll boost to 14psi, but if driving in 3rd onwards etc and booted itll make between 9-11 psi, it's weird.
    Made 188.7 g/s the other day on a standard map though so unsure.
  27. #66
    Mar 2010
    Durham NE
    578
    That could be down to air leak,wastegate chatter,turbo failing etc.."its like when a fan hits its cage kind" this makes me think of turbo failing,turbo blades fitting the casing under load..
    Eventually it will look like my mate car he had the same noise for a while..then pop.
    Best bit is to do the turbo play check and go from there mate,can you video the noise on your phone?
    James
    Silver Audi 8L S3
  28. #67
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill try but its hard when driving to record it, i dont think the phone will pick it up. Also is a tapping/knocking from the back of the engine around the turbo area lol.
    None of this sounds good does it haha.
  29. #68
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by AudiS3-Turbo View Post
    Well, that's f**ked isn't it!
    Homer Simpson
  30. #69
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    nahhhhhhh, a zip tie and it'l be fiiiiine
  31. #70
    XFi
    Jun 2010
    344
    Not sure if the S3's have these but it use to be an issue on old Clio's where the road speed sensor use to be faulty or wasn't grounded properly. Could just be another possibility...
  32. #71
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    And would it cause similar problems XFI? Anyone know if we have a wheel speed sensor?
  33. #72
    Mar 2010
    Durham NE
    578
    Yes,ABS speed sensors,they are not related to the engine bar the esp but if you had a fault it would show up in esp/abs ..
    James
    Silver Audi 8L S3
  34. #73
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    No faults.
    Well looks like TIP off and take it from their, i hope its not the turbo .
  35. #74
    Mar 2010
    Durham NE
    578
    Did you get any where with this bud ?
    James
    Silver Audi 8L S3
  36. #75
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Unsure mate. I think ive located it to the fuel pump, when car has 1/3 of a tank or less of fuel it struggles to start and seems to drive worse, anything over. 1/3 of a tank and itw banging.
    Anyway to test the fuel pump?
  37. #76
    coatesy's Avatar
    Oct 2010
    1,901
    Dani you know I sent you that message saying I'd sorted it .... it came back this morning and the car has only got a third of tank of fuel in it I like you thinking about the fuel pump I'm gettinga new one soon to with my hybrid build
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
  38. #77
    Westy's Avatar
    Dec 2008
    17,273
    Seems like quite a few fuel pump issues cropping up now. These cars must have hit the magic age for fuel pumps to pack in.
    S3 Build Thread
  39. #78
    S3 Paul's Avatar
    Oct 2006
    2,764
    Mine only strugled to start when the batery was on its last legs.
    Only sign i had that my fuel pump was dying was a lack of power,
    Easy to check with vag com.
    Noggy Blue 2001 S3
  40. #79
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Sorry coatesy i thought id replied lol.
    Well its doing the exact same thing my mates s3 did and his just went and left him stranded and im sure s3dave was struggling to start his car and that turned out to be the fuel pump too.
    Paul how do you test it?
  41. #80
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Mine does this as well, when its a 1/4 or less it stuggles to start. Think my battery needs replacing aswell but symptoms sounds the same as others on here.
  1. Is the end near??
    By dannyh in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2011, 19:33
  2. Debate "2010 Front End or S3 2008 Front End"
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2011, 23:36
  3. 170 tdi power issues. Wits end. Advice required please
    By coupsta in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th August 2009, 15:02
  4. And Now....The end is Near...
    By Calibos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2006, 18:17
  5. got here in the end!
    By imported_scrupes in forum The Welcome Section
    Last Post: 20th July 2004, 19:02
