EM TuningJMB Retrofits
    Oct 2011
    759
    fault codes/related?
    Hi
    these codes came up when scanned, the abs, traction control lights come on and go off intermintley and the abs stays on.
    codes are
    00283 ABS wheel speed sensor front left G47 intermintent
    00285 ABS speed wheel sensor front right intermintent signl outside tolerance.
    18010 power supply terminal 30 voltage too low P1602 intermintent
    01155 clutch mechanical malfunction intermintent.
    Are these codes linked?
    i thought the top 2 might be the cause of the bottom 2.
    Any ideas?
    any help much appreciated
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    I think the voltage to terminal 30 fault occurs when the battery has been disconnected
    Afraid I can't help on the others
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Are your battery leads tight? if so check the earth on the alternator/engine
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    1.8T SPORT AUM
    Progression Thread
    Oct 2011
    759
    thks for the replies
    my car went dead last night when i was trying out an ebay vag com cable thats the only thing it did do.
    the cable is a pain to say the least, they dont work and ive tried everything and read a million threads aswell lol
    Oct 2011
    759
  1. Fault Codes,need help
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2010, 23:55
  2. Fault Codes
    By stevehall in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th August 2010, 22:13
  3. Fault codes
    By MPP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 17:53
  4. Fault codes
    By ex_scoobydoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2010, 11:12
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
