Volks AutosEM Tuning
Results 1 to 9 of 9
    SuziA3's Avatar
    Oct 2010
    Basildon
    76
    Foglight conversion
    Right, being a girl and not knowing an awful alot about the Audis and best way of modifying them I need your help! I have a standard A3 Sport :-) would really like an S3 but so hard to find a decent one that's been well looked after with decent milage. But anyways getting back to the problem - I have an A3 sport, want to turn the front end that has no fogs into a S3 front end with fogs without changing the bumpers as it won't be a perfect fit. Blah blah blah
    I've been told by Audi it's possible to change the bottom half of my bumper to the ones with surrounds - that's not my problem, my problem is what's the best way to wire the lights up to work - without drilling holes or ruining the car? Is there a switch that can be put in?
    Above my stereo I have 4 buttons - only 1 button works for the rear window the rest are blanks. Is there a
    Button that goes there that I can use to turn the fogs on?
    Or
    Is there a better way! Heeeeeeelp people please, goto get her looking good for AITP (my first Audi event)
    "I may be a girl, but I'm not stupid"
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Does your car not already have fogs installed ??? rather than being in the lower part of the bumper they are inside your headlights.... you pull out the headlamp switch to turn them on ..... i modified mine to the lower setup and just ran the wires from the old fog lamps to the new .... i did write up on it here Audifans.net: You are using an invalid IP
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    SuziA3's Avatar
    Oct 2010
    Basildon
    76
    Yeah, I got that pull out switch but it only does backs don't it? Didn't know about the fronts.. My original plan was to wire them to that switch so when I pulled it out they all came on. But Audi said it can't be done as the wires come from the back :-S he said I had to put a new switch in ... Don't really want to start drilling holes into the dash! Lol
    What do you mean I'm using an invalid IP
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by SuziA3 View Post
    The S3/A3 bumpers are different if you install fogs you'll just have an A3 with fogs
    You can tap the line for the rear fogs I don't see it as a problem to power front fogs that you install. You'll need to find out which wire is for the rear fogs on the rear of the light switch.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    SuziA3's Avatar
    Oct 2010
    Basildon
    76
    That won't be a problem. Audi said I can get the bottom half of the bumper with surrounds and the bumper will look exactly like a S3 bumper - might be more hassel but cheaper than buying a new bumper! :-) guess its stick to the original plan and wire them to the rear fogs
    SuziA3's Avatar
    Oct 2010
    Basildon
    76
    Quote Originally Posted by TDIQ View Post
    I think I get what you mean now - Audi told me different but I'm guessing your right by looking @ your car. They the chrome wingmirrors? Or painted silver..? Standard - done them yourself!
    SuziA3's Avatar
    Oct 2010
    Basildon
    76
    Right still been digging for information on how I'm goin to do the switch and the wiring...
    This is not mine but what mine looks like VVV
    Is it possible to just swap it for this switch which already has it and either buy wiring look or create my own?
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    A3 Retrofitting front fogs on a facelift (wiring diagram and advise please) :)
    That explains what you need to do or buy the loom from Kufatec, they say you need a switch with front fog control on, but you could wire into the existing rear fog switch if you wanted.
    8L IS DE BEST
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    I never switch my front fogs on as they do f all.
    (i say I never do thanks to audi making the switch do the fronts first then the rears I guess I have had them on but it has to be bloody foggy and they still do f all)
    red to red black to black blue to bits
  1. A3 Foglight DRLS's? Anyone?
    By Seaneylad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2011, 07:11
  2. foglight drl's
    By FranA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st July 2010, 23:49
  3. S-Line Conversion foglight wiring?
    By Paul_c in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2009, 17:39
  4. Foglight grilles
    By wallacr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2008, 22:20
