Badger5Sky Insurance
    D89
    Jan 2012
    Fan, Temperature gauge and Coolant problem
    Hi, im new to the forum and was just wondering if anyone could diagnose my problem.
    i have an A3 2004 (53reg), the fan runs constantly at full pelt when im driving, the temperature gauge doesnt move from the start point and the coolant light flashes constantly (i regularly check the coolant and its always between min and max)
    on the rare occasion the fan will switch and run at a normal speed, the temperature gauge will work and the coolant light goes off so im guessing there all linked.
    anyone have any ideas?
    cheers
    Rory
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Is it an 8L (old shape) or 8P (new shape) A3?
    <tuffty/>
    colicabcadam
    all fans will run if you have the air-conditioning on
    my assumption would be this........
    the lower level coolant warning is prob a separate problem, so a new sensor here should fix it
    regardless of whether than fans are on or not, the engine should reach 90 and stay there, seems like a new thermostat will fix this
    as for the fans, please confirm that you have aircon off, if the aircon is off it'll most likely be a faulty radiator temp switch or a faulty fan control module
  1. Water/coolant temperature problem
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2011, 20:50
  2. 1999 A6 1.8T Coolant Temp Gauge Problem
    By N22CKS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th March 2011, 17:35
  3. temperature gauge a4 tdi problem
    By neal in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:01
  4. coolant temperature sensor problem.
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2008, 15:10
  5. Temperature gauge not working, bit of a problem
    By cookie_a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2008, 12:27
