Chris NottSky Insurance
    Jan 2012
    6
    audi s3 8l heater blowing hot air only
    hi i have an audi s3 that blows only hot air, it has been like this since i bought it. However it gets too hot and i have to turn the fans/ blower off (which mists up the windscreen) or open the window.
    i know people will say that, have i had my air con re charged??. i have not checked but will check after some advice.
    I was thinking if it is blowing hot air it would be the heat flap/ positioning motor~? because if i turned the temp down surely it would use more of the cold outside air. then if i needed it colder thats where the air con is needed???
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    Does it continue blowing hot air if you set the temperature to "LO", rather than just say 18 or 19?
    My A4 did something similar and it was the temperature flap motor that had failed. I got another off ebay and that sorted it.
    TD5 Land Rover Defender build
    Jan 2012
    6
    yes the heater blows hot air regardless of the temp set. only cooler at start-up but that's as expected.
    Jan 2012
    Basingstoke
    20
    I had a similar thing on an old pug 306 it only blew hot air and your couldn't turn it off. I got a new board from the scrapyard and it sorted it. Could try the same?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Scan the aircon module in VCDS (Auto HVAC) to see if there are fault codes... as Aragorn has suggested it sounds like a heater control issue and there should be a fault code I would imagine if thats the case...
    <tuffty/>
    Jan 2012
    6
    Thanks guies for your help. Took apart the glovebox etc today and found the heater flap motor was stuck after playing with the temp. I took it out and is now working fine. Will leave it a few days to see if it sticks again so will leave the glove box off etc for now. Anyway thanks for ur help
  1. Air con blowing hot and cold ????
    By Rabbid in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th September 2011, 08:28
  2. Heater blowing cold air!
    By xano_sa in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2010, 12:25
  3. AIR -CON BLOWING OUT HOT AIR ALL THE TIME!!!!....
    By jondonna8276 in forum Air Conditioning
    Last Post: 31st August 2010, 21:50
  4. Heater matrix - no hot air!!!
    By RickT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2007, 13:45
  5. heater blowing cold air please help!
    By dannyoct16 in forum General Technical / How To
    Last Post: 1st January 2005, 22:19
