JMB RetrofitsSky Insurance
    Nov 2011
    Finland
    131
    Coilovers and drop links
    Hi! I have been looking for new suspension setup for my 2001 S3 and was ending up to Spax coilovers.
    Then I noticed that on the description of the coilovers theres a note:
    (17) At over 50mm lowering at the front, a modified anti roll bar LINK is required to prevent fouling. These are available from SPAX. Struts will not fit cars with the anti roll bar link attached to the strut.
    I havent been under the audi so cant be sure but arent the S3 arb links attached to the struts?
    Found out that at least the mkiv golf and a3 fwd has arb links attached to the control arm so does the s3 has that hole also in control arm?
    Or has anyone done some DIY brackets to the struts to get the links attached?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yes on s3s they are on the struts
  1. JOM coilovers and shortened drop links
    By antdsg in forum DPM Performance
    Last Post: 12th August 2012, 11:31
  2. Coilovers and shortened drop links?
    By antdsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2011, 17:32
  3. very low on coilovers. with adj drop links.
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2011, 22:06
  4. Car on coilovers is it worth shortening the drop links?
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2010, 17:29
  5. Drop Links
    By Kev_M5KPL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th November 2008, 21:29
