JMB RetrofitsChris Nott
Results 1 to 19 of 19
    Aug 2009
    Cheltenham
    335
    Narrow to Wideband ECU Conversion
    Hello,
    Has any one got a PDF or a good link (with photos) for the conversion of the narrow to wideband ECU.
    Unfortunatley Vortex no longer has the thread:-
    VWVortex.com - 1.8T (06a) Narrowband to Wideband Conversion Done Easy!
    Audizine and others have no photos:-
    1.8T (06a) Narrowband to Wideband Conversion Done Easy!!
    It looks like there are a few ways to do it.... Add wires to the existing loom, Replace Part of the loom or purchase a expensive conversion cable.
    Any helpers
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I will add the pins when i do it on mine.
    I have just gone from DBC old M3.8.3 ECU to ME7 DBW so want to get that working correctly first, then add the wires i need for SAI, 2nd Lambda etc and then change the ECU, conversion done
    Aug 2009
    Cheltenham
    335
    I was planning to to the 'added wires' route, what is your plan for the EGT probe and the VVT?
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Ive done this and its pretty easy tbf. I added the relevant cores to my existing engine compartment loom to get the correct lambda sensor plugs and EGT plug. The actual engine loom i just replaced with a good BAM version but that would be easy to convert also, youd have to remember if its for an APY S3 that all wideband ECUs have VVT so youl have to add that also, or get it coded out of the ECU.
    Audi S3 1.9 GT30....
    ....that is all
    Apr 2004
    12,523
    Ill get the egt probe welded to manifold probably and resistor out the vvt for now till it can be reliably used to aid spool time
    Aug 2009
    Cheltenham
    335
    I have got a APY setup at the mo, So if I go for:-
    1) AUM lambda side of loom that should cover the egt and lambda probe wiring with a loom swapout.
    2) Add a wideband lambda sensor
    3) Add a EQT probe
    4) Replace ECU with a AUM ECU and recode the clocks
    5) Add the additional wiring for the VVT on the engine loom and do a resistor mod.
    Would that cover it?? or is there something else?
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Apart from the AUM doesnt have EGT. Being an ME7.5 it can be coded in if you want it.
    ....that is all
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Yeh i'd just use a non-EGT ecu, only the 225 engines have it, and its just another thing to go wrong. I've got an AUQ ECU for mine, but a narrowband harness like Mark, so i'll also be adding the pins for the lambda and resistoring the VVT.
    TD5 Land Rover Defender build
    Aug 2009
    Cheltenham
    335
    Quote Originally Posted by MUSH View Post
    Ahh.... That might be a good thing... is there much to be gained from the egt probe... other than heat protection?
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Quote Originally Posted by Barks View Post
    Yep.... Problems!! Lol the sensor alone is £180ish and theyre known for letting go. If your not bothered then i wouldnt worry about the EGT. The k03 cars manage well without it. As its for tuning purposes it would just be good for your tuner to be aware of rising EGTs when mapping.
    ....that is all
    Aug 2009
    Cheltenham
    335
    Ha ha! Sounds like it is best not yo bother with the egt then. I haven't got one now!
    Aum seems to have 2 lambda probes. Wideband pre cat and narrow post cat Will i end up with issues with a sports cat?
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Depends what spec cat you have. The post cat narrowband just wants to see high oxygen levels to check the cat is working. When i fitted an AUQ in my old mk2 golf i just secured the post cat lambda in fresh air until i had it mapped when the coding for the sensor was removed from the map. Im doing the same now, its sat on top of my exhaust manifold! lol.
    If you do want to keep it and it causes issues then you can spacer it out of the exhaust gas stream to fool it into keeping quiet
    ....that is all
    Aug 2009
    Cheltenham
    335
    Ah I see, It is a 200 Cell decat,
    shouldn't be to much of a problem as is sounds easy to bypass.
    Is there a engine version that has single wideband Lambda and no EGT?
    Aug 2009
    Cheltenham
    335
    So how will you deal with the second Lambda?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    What do you guys gain out of doing this ?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    my wideband 210 has egt.
    beachbuggy's Avatar
    Surrey
    1,746
    Amk is a 210 and has EGT
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by A3 T View Post
    I believe its more accurate and.easier for a tuner to work with.
    Aug 2009
    Cheltenham
    335
    The wideband are 'easier' to map as the wideband lambda controls the fueling, like a closed loop circuit therefore you can just request a A/F ratio and the ecu will maintain the fueling and keep it in the sweet spot.
    With the narrow band you have to map the fueling up the rev range and engine load, makes it very difficult to maintain the A/F ratio sweet spot.
  1. Facelift ecu conversion
    By steady jay in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th August 2011, 18:09
  2. Wideband or non wideband lambda sensor????
    By Pedrosousa in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2011, 19:13
  3. 7J wheels to narrow?
    By will89 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th May 2011, 18:47
  4. wideband conversion thread
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2010, 08:37
  5. Installing Wideband on narrowband ECU/car
    By gmx in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th August 2009, 19:26
