AH FabricationsEM Tuning
Results 1 to 9 of 9
Thread: Fuel Gauge Dead
    Jun 2003
    133
    Fuel Gauge Dead
    One month out of warrenty and the fuel gauge has decided to die, needle is on zero, DIS is displaying Zero and fuel indicator is on.
    Anyone with any experiance with this fault, is it the sender unit or the cluster. I'm thinking the sender unit seeing as i have all 3 indications and what cost will this be to repair?
    Jun 2003
    133
    Re: Fuel Gauge Dead
    No one [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Where is the location of the Fuel sender?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Fuel Gauge Dead
    do you have vagcom or access? You can check how many litres are left in your tank using it on the cluster info module.This could ascertain if it is the sender or the display. The sender is in the tank IIRC
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Re: Fuel Gauge Dead
    Mine did this once - but it sorted itself out the next time I filled the tank.
    Aug 2003
    Surrey
    469
    Re: Fuel Gauge Dead
    Same here - mine went weird when I let tank get low (I normally refuel at 1/4) and needle went full-empty-full-1/2-full-empty.
    After refueling it that time it hasn't done it since, but I also haven't let it get that low.
    I put it down to the sender getting crap on it or something, but who knows.
    Jun 2003
    133
    Re: Fuel Gauge Dead
    No i dont have VAG-COM.
    Its started working again today. I'll wait and see what happens when i fill up next time.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Re: Fuel Gauge Dead
    Mine is doing exactly the same!
    One minute its ok the next its dropping right down like a stone!
    ELIASGK74's Avatar
    Mar 2004
    greece
    47
    Re: Fuel Gauge Dead
    today mine was moving left and right!
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    Re: Fuel Gauge Dead
    mine reads empty for 10 min ish after been stood overnight
    then slowly creeps up towards some kind of reading
    it has also gone 1/4 tank out on the reading after a minute
    or so of rapid movement/ flickering pointer must have turned
    a bit on its
    warning light now goes out just past the 1/4 tank mark
    im living with it
    us the trip meter to decide when to fill normally 330 mile
