Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Alex C
Thread: Yet another problem with the s3
    Dec 2011
    609
    Tonight I replaced the the small vacuum hose that had spilt and the the inlet pcv breather pipe.I took the car a rather spirited drive and it seems a bit more responsive on acceleration.on the way home I pulled in to the petrol station for some fuel I open the filler cap and lots of pressurised air and petrol came gushing out can any one tell me or give me a clue to what's causing this ? Also if I remove the oil cap air gushes out as well
    Dec 2011
    609
    Also when the car is switched off I can open the filler cap and release the pressure with little to no fuel coming out but if I leave the cap of and start the engine fuel gushes out.
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    i would guess that if air rushes out when you take the oil cap off then its not breathing properly, have you checked for blockages in the PVC system?
    not sure how or if that would affect your fuel system though
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dec 2011
    609
    Quote Originally Posted by Alex C View Post
    Am I right in thinking that if it was not breathing properly it would not be running very? As its running better than it was before I replaced the the hoses
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I would check the pipes around the charcoal canister next to the screen washer bottle..
    Dec 2011
    609
    For blockages or being disconnected dave ?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I think it is suppose to vent there so maybe blocked?
    Dec 2011
    609
    There was on plastic hose that had split but got replaces with a silicone hose and made no difference.my charcoal canister is making a rather loud clicking noise,do you happen to know what hose is the vent hose dave ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Sounds like what ever you have done to repair the pipes you have either missed off a check valve somewhere or piped it up wrong... would appear both your engine and fuel tank is seeing boost pressure
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by Goubo1 View Post
    It goes to the bottom of the canister and out through the wing
    Dec 2011
    609
    <tuffty/>
    It was just the 2 braided hoses that lead under the manifold that got replaced dv to n249 hose and the plastic pipe I found yesterday from the charcoal canister.they got replaced like for like 1 at a time so I could not get them mixed up
    I opened up the filler tank and started up the engine and it gushed out on idle does this rule out the possibility of it being boost related as I was not on boost when this occurred ??
    Dec 2011
    609
    Cheers dave I will check that out
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    There are a couple of one way valves in use with the charcoal canister... one vac pipe comes from the top of the throttle body and the other from the TIP...
    Check the pipe work on these... if the tank is seeing boost then its more likely to be the one on the throttle body... there should be a one way valve on the pipe just before it goes into the hard pipe that runs across the back of the engine bay...
    <tuffty/>
    Dec 2011
    609
    <tuffty/>
    Tuffty would it be possible for you to show me this pipe on a picture if you could ?
    Dec 2011
    609
    Well the problem turned out to be a blocked breather
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    woop woop
    Goubo1 likes this.
    Alex S3 AMK
  1. problem after problem... juddering...
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2011, 21:09
  2. Update on problem and another problem!!!
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2010, 00:10
  3. Replies: 1
    Last Post: 21st August 2010, 19:41
  4. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
  5. A4 Tdi, engine problem AND steering problem! PLEASE help!!
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 16:02
