Chris NottSky Insurance
Results 1 to 18 of 18
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Indicators playing up - relay?
    Hi chaps,
    For some time now my indicators have been a bit temperamental - sometimes they flash fine, other times they have been flashing erratically (that's erratically, not erotically). Anyway, this week I've noticed that they now actually stop working after about 5-6 flashes, even if the indicator stalk is still in the correct position. Turning them off and on again solves the problem for another 5-6 flashes.
    I think this may be the hazard relay - any thoughts/advice on this one? Anyone had the same problem?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Hey Paul
    Hope you are well mate...
    It sounds much like the hazard relay that has gone, I did mine a while ago, cost about £30-40.
    It doesnt take much to replace either....
    You may need to remove your stereo and prise the whole hazard unit out, then just click the new one in place...job done
    Oh and I had the same symptoms as you.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Quote Originally Posted by The Doctor View Post
    (that's erratically, not erotically).?
    Good to see you again matey
    But Uh oh... Getting turned on by flashers lol...
    In all seriousness, It will either be the flasher relay or the stalk. Contacts in both can wear and cause issues like this.
    Currently rolling in a SKODA!!!
    Sep 2011
    268
    sounds exactly the same as a problem i had with my old 18t, was the hazard light switch.. got a new one from audi fitted it and never went wrong again, abit fidely as its actually attached to the back of the hazard light button itself, but it'l sort it bud 99.9% sure
    ROGUE TRADER
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Hazard switch for deff. It has 2 relays in it, one for hazards and one for indicators.
    It's why your hazards probably still work. iirc there is a later one than the std fitted unit and it's sub £40.
    Laterz
    32
    I have one spare from my track car if its any use to you? From an X reg A3.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    OK thanks chaps, that's what I suspected. I think I've seen a guide for the hazard relay replacement on here somewhere so will have a search, unless anyone has the link to that thread handy?
    Mark - yes the hazards are fine.
    I'll get myself a new one for that price, but thanks for the offer george_seamons.
    Nov 2011
    71
    I had this as my indicators were intermittent sometimes and only one side of the hazards worked, replaced the hazard switch and all was well.
    Mines a pre facelift s3 but i did it like this:
    Drop ashtray (1 screw in the centre)
    Remove stereo
    Remove 2 screws from where stereo was
    pull facia out and drop out of the way just enough.
    Hand into where the stereo was, couple of fingers up into the gap behind the hazard switch and push with a bit of force and out it pops.
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Crikey!
    I didn't have to remove the stereo! I just got off the faceplate over the ESP & cupholder and then it was accessible...
    You guys got aftermarket head-units, yeah?
    Snuff's Avatar
    satan's driver
    Aug 2011
    darkest caerphilly
    56
    my indicators have just packed in too , i hope i dont have to remove the standard head unit. is there a how to guide on removal
    Torque talks
    Doncaster
    61
    This happened to me today as well. Wouldn't work at all. Then worked if I pushed the stalk a little harder than normal, but only indicated left regardless of which way I was trying to indicate. Thanks for everyones replies as I would of guessed it was the stalk.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Quote Originally Posted by Snuff View Post
    Yes, see here:
    Removing Hazard button?
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    563
    Mine has just packed up too, it has been playing up on and off for a while, I wizzed it out before tea, a tap seemed to start it up every time it jammed. I have cleaned up the contacts and adjusted the common pole to be more central, it now seems to be working again so we shall see how it goes
    99 S3 Absolute red
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Mine stopped flashing then I put the hazards on and it's worked ever since lol. If its not entirely broke then it's a gooden
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    Quote Originally Posted by Gops View Post
    Ha !
    Yeah kid yourself it's not going to happen to your car,I did and guess what ? Two weeks later kaputt
    Nilz's Avatar
    Apr 2006
    9,640
    LOL!!!
    Gops, give it some time..my bet is on the way back from AITP tomorrow
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,527
    Lol well it's been ok for a month now. I know it'll happen soon, just hoping the car gods like me and keep it working till I can be bothered to get one. Dont jinx me nilz
    Nilz's Avatar
    Apr 2006
    9,640
    Sorry bro.xxx
    Im sure it will be fine
  1. Indicators: Hazard Relay.
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2009, 13:54
  2. Indicators Not Working - Relay or Stalk?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2009, 16:10
  3. Indicator Relay Playing Up
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2008, 17:42
  4. Indicators playing up
    By Ballcrusher in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2007, 07:35
  5. HELP! Indicators playing silly buggers!
    By 1210tech in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th February 2007, 22:34
