Monster MotorsportEM Tuning
Results 1 to 13 of 13
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    dull scratched headlights
    my headlights are dull scratched and just generally sh!te, has anyone else had this?
    is it a case of new headlights or could they be polished out?
    sorry if this has been covered before, had a search but on the iphone and its pants haha
    thanks in advance :-)
    knoxie
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    My minor modding thread
    Here you go...
    <tuffty/>
    Sep 2011
    Isle of Man
    175
    Hi is easy to polish out by hand using cutting compound. If you have a look on YouTube there are a few vids showing how
    I did mine made a big difference just needed a bit of elbow grease !
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    I have read several tutorials and write ups on refurbishing plastic headlights most of which involve using wet and dry sandpaper first followed by a machine polish... sounded easy enough but sanding the headlight with wet and dry scares the life out of me but I decided to give it a go...
    Here's the kit I used...
    As you can see from this pic the headlight is fairly rough...
    ...still a bit worried about sanding the whole light so tried it on a small patch in the corner... used 2000 w&d with water of course then went over twice with Menz final finish which resulted in...
    ...happy with that I proceeded to mask up around the light and sanded the whole light face with 2000 w&d...
    ...ended up looking like this...
    ...dried off the water and finished up doing 3 passes with a soft pad an Menz final finish..
    ...the result of the first pass...
    ...and the final result...
    ...compared to the passenger side that I haven't done yet...
    ...and finally a comparison with the headlights on...
    Before....
    After...
    Moved over to the passenger side headlight...
    The result of 3 more passes over with Menz final finish and a spot pad on a Kestral DA this time...
    Looking at this one compared to the passenger side one I decided I couldn't wait and cracked on with sorting that one out too... feeling more confident of my abilities now I went straight in with 1000 grit wet and dry which took a bit of work to get an even finish then worked the light over with 2000 grit wet and dry as before....
    This is the point where you would justifiably feel sick as a pig looking at the very opaque headlight.... Just to reassure you I taped up half the light and did a single pass with the DA...
    ...as you can see its pretty easy to get the finish back but use a hardish pad as my medium pad had got saturated and ended up using a soft pad which took god knows how many passes until I was happy...
    Reminder of the light before..
    ..and after...
    Next thing to do is to get some the Lamin-x film to protect the headlights now the UV layer has been removed and to help protect against stone chips...
    A worth while job to do considering these headlamps are something close to �500 each from a dealer to replace..
    <tuffty/>
    Jan 2011
    Swansea
    73
    Hi there, awesome results!! What circular polisher do you have? Do you think a dual action polisher would suffice here?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    996
    Quote Originally Posted by cagiti View Post
    I was going to ask the same question.....lol
    There's also this thread: before and after pics of refurbed prefacelift headlights
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    thanks guys, i was thinking about w&d'ing it but as you said scared me a bit haha thanks very much tuffty you really are top
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Dual action... normal polisher would make things too hot and melt the plastic... the one in the picture is a Silverline DA sander which goes low enough speed for this or I have access to a Kestral DA6
    <tuffty/>
    mattyboy199's Avatar
    Nov 2005
    UK
    1,676
    Turtle Wax do a headlight restoration kit. I actually bought it as i had a headlight replaced by my insurance, the other headlight looked pretty weathered & this did tidy the lense up. The problem i have is the internals fade & a new HID headlight is £500, my plan is to purchase a halogen casing & swap everything over.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    colicabcadam
    will defo use this thread, my ktm headlight will love this, well done tuffy
    Chugger
    North Devon
    2,716
    yeah i did this with my lights last year, it is frightening stuff when you start on the heavier gauge paper. But they came up much better after sanding
    57 A3 2.0 TDI Sportback (140)
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    where can you get this 'lamin-x' from? can you get pre cut to the size we need? or is it a case of cutting yourself?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Lamin X
    <tuffty/>
  1. Anything I can do with my dull headlights?
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th November 2011, 18:04
  2. alloy wheels DULL?
    By philip.levis in forum Detailing
    Last Post: 13th June 2011, 09:40
  3. xenons gone dull
    By mattys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2008, 12:48
  4. Dull White Paintwork
    By axelfols in forum Detailing
    Last Post: 11th April 2008, 13:13
  5. Dull
    By Just Plain Old in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2004, 20:20
