Chris NottEM Tuning
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By S3Zek
Thread: Self levelling headlights???? Please help
    Jul 2011
    Please! does anybody have a clue as to why my usually awesome HiD lights seem now to automatically after turning on but seem to end up pointing down as if i am carrying loads of weight. There is no provision to manually adjust so can i presume their is a fault?
    Any insight would be greatly appreciated.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Fairly common problem... the motors for the self adjusters are the culprits... typically fixed by replacing the motor on the affected headlamp... you can take the motor apart and clean the level potentiometer (there is a guide on here somewhere) but its not always successful and you may end up having to replace the motor anyway...
    Resetting the headlights is done through VCDS software or a dealer... there is manual adjustment to fine tune as the software adjustment is to sync the motors so the lights move the at the same time not to adjust where they point..
    Having a working self levelling system and headlamp washers is an MOT requirement for Xenon/HID headlamps from Jan 2012
    <tuffty/>
    Sep 2011
    268
    happened to me recently, ended up being a broken rear sensor, the tie bar that runs from the rear arm had snapped the little plastic arm on the sensor, fixed by drilling a little hole in the remaining palstic arm and re attaching the 2 with a cable tie, been fine again for weeks
    give that a check
    ROGUE TRADER
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    I had what Rogo says happen with mine. Unfortunately my sensor was beyond repair and had to buy a new one in 2010. After 6 years of living with the lights being random, it's nice to now have headlights that consistently point at the right level!
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Sep 2011
    268
    Quote Originally Posted by jcs356 View Post
    haha i used to be like that.. id live with stuff not working properly for ages, then id end up getting it all up together and sorted a week before i got rid of it!! lol
    ROGUE TRADER
    fran-s3's Avatar
    1,090
    Can you remember how much the new self levelling sensor was at all?
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Just checked the bill and it was £60.85 plus vat in summer 2010. I also thing there is a mounting bracket that you might need, depending upon the condition of what is on the car. Mine was completely destroyed when my Forge adjustable tie bar snapped.
    TBH when my lights didn't level I was put off trying to get them fixed as I thought it was the motors in the lights themselves (i.e. expensive!) Had I know it was just the sensor that was playing up I'd have fixed it sooner.
    Jason
    S3Zek's Avatar
    Sep 2011
    407
    mine keep playing up also, every time i turn them on they would level out then as soon as i drive one points at the flour lol, i always wondered how to fix them, but for temp i turned them on to level them out then unplugged both of them.
    been like that for the last 2 years lol
    AARON77 likes this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    If one drops to the floor then its normally just the motor thats the problem... the self levelling system is on the K-line too so will throw fualt codes... if the self levelling system has a problem then a scan should show them up and give you a better idea on whats going on...
    <tuffty/>
    Oct 2006
    North Herts
    130
    Anyone know where abouts the sensor is located?
    Jit
    Audi S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by jitvv View Post
    One under the passenger side front wheel arch (bolted to inner arch and connected to the lower wishbone) and the other at the rear bolted to the rear subframe and connected to the lower tie bar for the rear suspension again on the passenger side...
    <tuffty/>
    Sep 2011
    268
    front passenger side and rear passenger side, whip the wheel off and you'll see it bud..
    ROGUE TRADER
    Oct 2006
    North Herts
    130
    <tuffty/>
    Thanks guys
    Jit
    Audi S3
    Oct 2006
    North Herts
    130
    Thanks guys
    Jit
    Audi S3
    S3Zek's Avatar
    Sep 2011
    407
    <tuffty/>
    cheers for that tuffty will have a look at the weekend and see if it shows up anything, as long as I remember to plug them back in.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    Sorry to revive an old thread but .....
    When I had my coil overs fitted. The muppet fitter has broken the self leveller on the rear axle.
    Didn't bother to tell me though. Just tie wrapped it up.
    I have spotted it and want to replace it.
    Does anyone know the part number for it please?
    Thanks.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    4B0 907 503 There's a few on fleabay.
    Can't you get the monkey that did the sus. to pay for it?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    Quote Originally Posted by vfr800 View Post
    Thank you mate.
    Just wanted to check they are the same across the different models. Looking at a TT one now.
    No not worth the grief. Just wont use him again.
    Found a number of cock ups he made.
    Do it myself in future.
    2001 S3 (AMK)
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    does anyone know the vcds procedure for resetting the lights?
    Im sure mine do not auto adjust
    they dont point down but deffo do not auto adjust... like my M3 does
    thanks
    Dave
    2001 AMK Dolphin Grey S3
    epox's Avatar
    Oct 2012
    Glasgow
    482
    Basic Setting
    Headlight Adjustment
    [Select]
    [55 - Xenon Range]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    • The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    • Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    Don't forget to check/clear fault codes afterwards.
    [Close Controller, Go Back - 06]
  1. Auto levelling retro fit
    By chrisa4quat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th December 2011, 20:01
  2. Xenons not self levelling.
    By S3 Harj in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2010, 21:48
  3. Self Levelling Xenon with DRL's Fault
    By Lion Man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2010, 09:25
  4. S3 Xenon headlight levelling -
    By subby in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2009, 11:03
  5. S3 Headlight alignment/levelling
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 23:14
