EM TuningChris Nott
    Sep 2009
    98
    Help needed key fob issue
    just changed the batteries on my 2001 s3 feyfob and the remote wont work ive followed the manual's instructions press unlock and use the key within a minute it dont work tried all sorts of suggestions anyone shed some light on this common issue
    cheers
    colicabcadam
    i'd say you've used a dud battery, rom what i understand the keyfob is hard coded, even if you leave the battery out for days / months, it keeps it's identity, it's the keyfob that is then programmed to the car
    so changing the battery would't cause a problem, unless you changed it for a dud battery, why did you change the battery anyways? was it useless, even when next to the car?
    i am sure other will let you know if i am correct or not
  1. What key fob do i have?
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2011, 11:11
  2. Key fob/flip key
    By RadCap in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2009, 14:37
  3. Key Fob....
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2009, 15:50
  4. key fob help needed
    By oneeye in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th January 2007, 22:38
  5. New Key Fob
    By mayurw in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2006, 12:41
