Help needed key fob issue
g dawg
NULL
just changed the batteries on my 2001 s3 feyfob and the remote wont work ive followed the manual's instructions press unlock and use the key within a minute it dont work tried all sorts of suggestions anyone shed some light on this common issue
cheers
i'd say you've used a dud battery, rom what i understand the keyfob is hard coded, even if you leave the battery out for days / months, it keeps it's identity, it's the keyfob that is then programmed to the car
so changing the battery would't cause a problem, unless you changed it for a dud battery, why did you change the battery anyways? was it useless, even when next to the car?
i am sure other will let you know if i am correct or not
10
930
671
993
7
971
749
