EM TuningVolks Autos
Results 1 to 9 of 9
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Can I throw my hockey puck in the bin
    Have been trying to tidy my engine bay up out of pure boredom
    I've already ditched the carbon can and n249 and vacuum gubbins
    Now can I put a brether filter on the rocker cover and block the hose from that comes from the engine and goes to the hockey puck?
    Then bloc the hole I'll have left in the TIP
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    no, you cant simply block the crank case vent.
    if anything, block the one on the rocker cover (AEB's and other longitudinal engines dont even have a rocker cover breather as standard) then route the block breather down under the car so it doesnt stink inside the cabin.
    You can then remove the puck and block the hole on the tip.
    Not that familiar with the transverse engines, but if theres an oil seperator on the block then leave this inplace.
    TD5 Land Rover Defender build
    Sep 2010
    89
    I'm planing on doing the same thing, if I put a breather on the crank case under the car, will it leak oil at all ?what's a Transverse engine mate? Mines a AGU so I don't know if it's safe to remove the puck or not,
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Has anybody done this ?
    beachbuggy's Avatar
    Surrey
    1,727
    Search for "catch can" basically the same thing
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Yep catch can is the posher/more responsible way to do this..... plus does not leave oil deposits on the road for our fellow bikers....
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    I'd rather eliminate it altogether if possible ?
    Steveo_A3_1.8t's Avatar
    Mar 2009
    Great Wakering, Southend
    196
    What does the hockey puc do?? Is it like a big one way valve??
    Noob alert ha ha
    "Oh shut up you tart!"
    "Stick a V8 in it!"
    14,914
    You cant simply eliminate it.
    Blowby will occur, and needs to get out of the crank case. That means you either pipe it to a catch can, or out under the car.
    As dave says, simply dumping it under the car will result in oily mank being deposited onto the road surface. A catch can will reduce this. You might be able to use an oil seperator rather than a catch can, which catches the oil and lets it drain back down into the crank case.
  1. Nice little build thread vid, and evidence of the dreaded con rod throw :(
    By Rogue-24-84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2012, 01:06
  2. Hoses around the hockey puck
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2011, 21:20
  3. PCV "Hockey puck" pipework.
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2011, 19:18
  4. at what point do you throw in your keys?
    By Matt82 in forum General Automotive Chat
    Last Post: 17th April 2010, 00:32
  5. Short throw shifter
    By Mordendrak in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th January 2005, 00:56
