Results 1 to 7 of 7
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    Another aftermarket stereo question. Bose - Alpine...
    Just been fitting My alpine head unit, in favour of the old Concert CD (Bose)
    I couldn't find a switched live feed. Does anyone know which wire this should be? I tried with my test light but could only find a permanent live, so now the alpine won't turn off with the key..
    Another question, do I need an aerial adapter? I've plugged the aerial in but have no reception. There is another plug that comes off the aerial loom, which plugged into the original stereo, but of course nowhere for it to go on the alpine.
    If anyone has a link to the adapter I need that would be a big help!
    I've used the connects 2 CT51-AU01
    Cheers in advance, Ash
    2003-03 8L S3 Dolphin grey - Porsche 996 calipers - Mo-vit 325mm 2 piece front discs - 15mm spacers all round - Miltek resonated cat back - Genuine RS4's - Vredestein Sessanta's - Forge 007p - Forge TIP - JR cone filter - Poweflex diesel dog bone bush - AMD Remap - Blue Haldex controller - FK AK Coilovers - Seat Leon Cupra R top mounts - 8P S3 gear knob and gaitor - TT pedals - Neuspeed quick shift - LED number plate bulbs
    14.2 quarter @ 97 mph
    Power? 241 bhp with a boost leak, now fixed
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Have you got full Bose?
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    If you have full Bose then you need the Autoleads PC9-410. I know this because i just done my sound install.
    Jun 2003
    World of my own
    9,813
    No there is no switched live at the HU, the facelift 8L's all use the CANBUS to tell the HU when to go on/off. You need to run a separate feed from the fusebox as the feed is still there just not wired up. It's fuse labelled Radio S-Kont, just make sure you tap the cold side (the side protected by the fuse) and then you don't need to wire in a separate fuse. This feed gives you a proper accessory feed that stays live until you pull the keys out, just like the concert. Or you can waste £60 on a CANBUS emulator
    Alex Turner
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    Yep, I believe it's full Bose. The head unit says Bose when you turn it on and all the speakers are Bose.
    Cheers or the info AndyMac. I'll do this at the weekend. Is it just a case of removing the drivers side lower dash to get at the back of the fusebox?
    Any ideas on the aerial? I presume it needs a feed or a convertor?
    Jun 2003
    World of my own
    9,813
    Yes and yes, you need one of these:
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    And connect the blue flying lead to the power antenna feed on the Alpine
    Alex Turner
    Ashley g's Avatar
    Feb 2011
    High Wycombe Bucks
    178
    Again, thank you!
  1. Advice on Aftermarket Alpine stereo for Audi A4 B7 - FM RADIO!?!
    By urbanxperience in forum In-Car Entertainment
    Last Post: 26th January 2011, 15:01
  2. Aftermarket Stereo Wiring Question Audi a3 8p
    By dot32 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2010, 21:38
  3. Help! Aftermarket stereo *really* loud (A3/Bose)
    By maxp in forum In-Car Entertainment
    Last Post: 12th June 2010, 18:24
  4. Alpine HU replaced BOSE stereo
    By ak_quattro454 in forum In-Car Entertainment
    Last Post: 15th November 2006, 19:12
  5. Aftermarket stereo to Bose upgrade mod
    By rich dj in forum General Technical / How To
    Last Post: 18th August 2006, 14:22
