Chris NottBadger5
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Oil cooler pipes corroded
    Woke up this at 5 morning to a nice lil puddle under the car
    Checked the water reservoir and that was empty! Not so bad as it was str8 bak to bed for a few hours
    Anyway this is what I found in the day light
    Oil cooler pipes had corroded so much that water had escaped
    Was an easy fix tho, just had to take off a a few pipes and the throttle body so I could get to oil cooler.
    Then just popped off the two pipes and sanded all the corrosion off the alloy pipes attached to the cooler.
    before
    After
    Was just a case of putting it all back together
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    I bet you were p****d at that time of the day!
    Good job done tho!
    Pat
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Part n parcel of driving old bangers
    Wasn't to gutted only lost a days wages
    Was free to fix !
    Could have been worse could have happened on the motorway
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by AARON77 View Post
    Was free to fix !
    You are not wrong there!
    Pat
    Lewis583's Avatar
    Mar 2010
    870
    Had to do the same on mine. The pipes were stuck on at the other end too, which promptly torn trying to remove them so had to buy a new pair. Not cheap at £36 inc VAT
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. S3 oil cooler
    By 8pot in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2012, 15:01
  2. oil temp/oil cooler
    By tangerinedream in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2011, 12:14
  3. Oil cooler?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2008, 08:52
  4. Oil Cooler
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th September 2007, 18:47
  5. Oil Cooler
    By imported_rosssummers in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2004, 22:42
