Volks AutosAH Fabrications
Results 1 to 8 of 8
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well, Mr S3... you better be happy !
    Today has been a busy day...
    Car got itself alot of TLC...
    Parts fitted today...
    R32 rear ARB
    Poly Bush's anywhere on ther rear that would take em
    Rear and front Drop links
    Passenger front drive shaft
    New rear exhuast heat shield
    Full engine service
    Coolant flush
    and then... found three punctures.
    I managed to trap my finger ( badly) in a transmition stand as i lowered it
    Bloody thing better drive well now,
    I took some time to look over my brakes,
    Some of you may know i think they are shocking,
    I have Brembo GT jnr kit and strugle to stop twice from speed,
    I have been thinking discs and pads... turns out the discs still look very new, ( fitted 3 months ago) the pads ( EBC yellow stuff) not so fresh, The fluid was changed for ATE racing blue about 6 months ago
    Is it worth just changing the pads to something better??
    Noggy Blue 2001 S3
    Aug 2010
    bradford
    1,239
    Ds2500 mate I'd say
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    oh so not much then!
    must drive a lot better now
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Did you need a bush press to put all the bushes in?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well after a few days of use im very happy with how the car feels.
    I know its been said sooo many times but... The rear anti roll bar has realy sorted out a big problem i had almost decided was the cars main failing.
    Why the hell did Audi fit a paper clip as a rear bar on a so called sporty hatch?
    VW fitted the better one so why not Audi ? Or is this something to do with the recall there was on early TT's? Didnt the soften up the rear set up to make it more hair dresser friendly?
    Noggy Blue 2001 S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Quote Originally Posted by S3 Paul View Post
    The R32 is heavier up front so it required stiffer bars to get it round corners while still maintaining a load of understeer for the average driver. The early TT's were recalled due to people getting lift off oversteer and ending up facing backwards in a hedge
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    May 2010
    Bedford
    2,877
    Also why they added on a rear spoiler^
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ah,
    Well im happy to report i now have alot less roll into the corners.
    Its like going from standard suspension to sports set up all over again !
    Ive not pushed it realy hard but i think it will either give more feel in the corners at speed and a little more stability.
    Noggy Blue 2001 S3
  1. Happy as can be
    By lespaul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th June 2011, 22:24
  2. Im not happy.......!
    By barnzy in forum In-Car Entertainment
    Last Post: 9th February 2011, 07:58
  3. Not happy
    By MPP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2010, 01:33
  4. Happy Ever After???
    By MikeA3 in forum General Chat
    Last Post: 12th August 2005, 06:34
  5. have a happy one
    By VACINC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th December 2004, 11:40
