Monster MotorsportChris Nott
Results 1 to 9 of 9
    Jan 2012
    UK
    7
    S3 with Halogens??? Help :(
    Hi All,
    Before I get found out and Booed off the forum I'll own up to being a VW owner. I'm currently in the middle of converting a VW Golf Mk2 Syncro to run the S3 engine, wiring, dash, 4x4 etc etc... (this is where you guys come in ). The S3 I bought seems to have halogen headlights instead of xenons.
    It is a 2000 model (8L) and being an S3, should have xenons, no? It has all the auto leveling sensors fitted and also shows xenons on the VAG COM readings. I know it's been involved in a front end accident at some point as the passenger side has evidence of repairs which leads me to believe that the previous owner cut costs on the repair and fitted halogen headlights instead of xenons.
    What baffles me is that the wiring loom has the correct connector for the halogen lights and it doesn't look like it has been altered. I've taken a pic of the back of the headlights to show the connector:
    [img]http://www.notaracer.co.uk/syncro/SAM_7136.JPG[/img]
    From what I can see on ETKA and from pics of the back of the xenon headlights, the connectors are completely different.
    Any ideas??
    Thanks,
    Kav
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Im not to sure on the connectors but i believe they all came with xenons....
    Sep 2011
    268
    all s3's came with xenons as standard...
    ROGUE TRADER
    Jan 2012
    UK
    7
    Yeah i thought as much. Can someone with an early S3 have a look at their loom to confirm its defo not the round type as in my pic? Is there a loom in between the round connector and the headlights?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I don't have a pre-facelift but they look OE to me, and I'm sure all S3's came with Xenons. Pre-facelifts do have different lamps/projectors but I'm sure they're still Xenons.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Jan 2012
    UK
    7
    Sorry I forgot to mention - the pic is of the halogen headlights that are on the car. The connector on the wiring loom fits these (halogen) lights. I just wanted to see what the connector is like on the xenons.
    Thanks,
    Kav
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    What you have is the facelift lights put on there. The preface lift had square connectors. Check your loom, there might be a connector from square to round. If not just keep that loom and run HID kit as the lights will have projectors? I'll try and take a pic if my loom later as my car is on the other side of the hosp here and it's cold outside lol
    Jan 2012
    UK
    7
    Thanks matey, that would be most appreciated.
    I think they're the pre-facelift lights as the indicator is separate. They're defo the halogen ones because there's an H7 bulb with no projector. I'll take some more pics when I get home tonight.
    TBH it's not the end of the world if I use the halogen lights, but I would quite like to fit the xenon projectors/leveling etc to the mk2 golf
    Jan 2012
    UK
    7
    Ok...mystery solved...I undid the black wrapping from around the cables and....
    Can someone have a look at the colours at the back of their passenger side xenon headlight connector and confirm that the four colours in the pic below go into that connector?
    Yellow/Blue
    White/Black
    Grey/Black
    Brown
  1. Xenon lights from 8P1 to replace Halogens in 8P1
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2011, 20:53
  2. Single xenons oem for audi a3 2004 Simple swap for halogens?
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd February 2011, 19:25
  3. What headlights are mine? Halogens or Xenons?
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2011, 17:26
  4. Sorting those facelift halogens
    By lothian in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2009, 22:11
  5. HIDs Swapped out - Back to Halogens
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th April 2008, 15:44
