Chris NottSky Insurance
Results 1 to 9 of 9
    got an S3 8L: living the dream
    Mar 2010
    Kent
    171
    Question Engine oil additives for cold start wear reduction.....worth it?
    Hello all,
    What with the cold snaps we have been having (albeit sporadic) and the cold weather to come (i presume there will be), i have been a little concerned that my engine barely has time to get up to temperature before i get to work (only 5 miles).
    When i was in halfords picking up some consumables the other day i saw some engine oil additives that claim to reduce friction especially for cold starts.......magnatec style properties i presume.
    Does anyone have any opinion on these? Good? Bad?
    Names i saw were Molyslip engine protector, Extralube ZX1 and Slick 50...........links below to halfords web pages for these.
    If there is anything i can do to help protect the engine for such short journeys it must be a benefit surely?...........any input would be appreciated!:
    Halfords | Molyslip Engine Protector 325ml
    Halfords | Extralube ZX1 Micro Oil Treatment
    Halfords | Slick 50 High Performance Synthetic Engine Treatment 750ml
    2002 S3 8L AMK
    Jan 2011
    northants
    165
    not worth it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Decent fully synth oil changed regularly is all you need...
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,759
    Are you using Quantum stuff Tuffty?
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Quote Originally Posted by S3 Paul View Post
    Quantum Platinum
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,759
    Do you only use VW filters from the dealers or are Bosch ones from say GSF or Eurocarparts as good?
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    GSF in the past (MANN filters), Bosch from ECP or OEM from TPS which I think are MANN anyway... I use any of those that happen to be on the shelf at the time...
    Last oil change was a VAG one... when I dump the oil after running in the engine it will be a Bosch as that what Bill currently has on the shelf..
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ah ok ,
    I have been told that The one for my 2001 S3 is the same as that for the engine in my Mk2 golf ( ABF 2.0 16v )?
    I carry a couple for that car in the garage,
    Ive used millers oil for the summer but think its too thick for the winter so needs to come out
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Ah ok ,
    Probably is... VAG are lazy when it comes to parts and not only share them across marques they share them across versions too...
    I use 5W40 all year round... just drop it every 5k
    <tuffty/>
  1. Oil additives
    By TURBOTRONICS in forum General Automotive Chat
    Last Post: 7th June 2010, 17:02
  2. A6 2.0 tdi cold / not start - engine hesitation
    By JimC64 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th September 2009, 13:56
  3. a3 1.8 turbo cold engine start loud screech
    By munkyman in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 06:04
  4. Engine Additives!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 20:37
  5. checking oil level - engine hot or cold?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2006, 11:53
