JMB RetrofitsVolks Autos
Page 3 of 3 FirstFirst 123
Results 81 to 91 of 91
Like Tree1Likes
Thread: Sounds expensive.... lol.
  1. #81
    RIP S3dave
    May 2004
    nr Glos
    7,166
    Let's derail the thread some more...
    Bill, whats it like trying to race a fwd 600odd HP car, surely there comes a point where 4wd would be able to utilise that power more of the time?
    Or do you win the races anyway so it doesn't matter lol
    in race trim its turned down to tractable(ish) level
    on full chat it will spin up every gear in the dry, so not much point.. We have to use list 1a tyres for combe saloons, which is regular tyres.. not even track day rubber, so that limits power effectively. Its nice to know I have it is about all I can say - lol
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  3. #82
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK, so to re-rail - the Haldex is not working at all again this morning, making the yellow thing like a nuclear bomb with no guidance system.
    I was hoping really that this problem would just go away, but sadly that appears to not be the case. Booo.
    Will go out and scan it in a bit.
    Homer Simpson
  4. #83
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Ahh man I remember when mine was fwd and that was mad.. Yours must be crazy! Hope you get it sorted mate! Good luck!
  5. #84
    colicabcadam
    what did you change? the whole unit? is the pump built into the unit? or is it external?
  6. #85
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Quote Originally Posted by colicabcadam View Post
    Is that question for me? If so I changed the controller, from what I know the pump is separate I think.
  7. #86
    colicabcadam
    Quote Originally Posted by Gops View Post
    LOL - for OP lol
  8. #87
    BENJAMIN's Avatar
    Mar 2011
    472
    Activate the haldex oil pump in output tests and get underneath to check the pump is buzzing away. When I replaced my diff, I fitted the new one to find it didn't work for 2 reasons.
    1- my replacement diff was off a 03 R32 with esp and mines a 99 apy with no esp. The late ESP controller did not work with my non ESP car. Weirdly the r32 haldex ecu wouldn't even communicate with my abs (can bus difference possibly?)
    2- the replacement diffs oil pump wasn't working properly and made the car run in 2wd all the time.
  9. #88
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not changed anything yet, trying to avoid changing anything...
    Homer Simpson
  10. #89
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by BENJAMIN View Post
    I ran the output test earlier and I could hear the haldex doing it's thing. Have been driving it about today as well and have had no AWD issues. Intermittent at best, and the front only seems to spin in the wet.
    I wonder if the haldex is still working, but the front tyres just can't grip in the wet. Not sure. Weird. Having said that, had noises from the back recently which have stopped now, and a haldex fault code... It's got to be on it's way out to be fair.
    Homer Simpson
  11. #90
    Chugger
    North Devon
    2,716
    I hate to say it, but trying a simple oil change may do the job? Iv read loads of times that this fixes alot of problems
    57 A3 2.0 TDI Sportback (140)
  12. #91
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by sportstractor View Post
    Did consider that - only had one done inside the last 5K ish though. If problems continue I might before changing the whole diff.
    Homer Simpson
  1. tyres getting more expensive??
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2011, 23:30
  2. Worrying knocking noise...sounds expensive...what is it?!
    By Kermit in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2011, 21:48
  3. Most Expensive S3 I've Saw!
    By thelomondaudigroup in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2011, 09:50
  4. expensive brakes!!
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2007, 16:31
  5. Expensive Nova
    By james0808 in forum General Chat
    Last Post: 21st June 2007, 05:27
