Like Tree1Likes
  • 1 Post By confusionhunter
Thread: Central Locking doing my head in! Fuse?
    Nov 2005
    lothian
    181
    Hi Guys,
    Ive suffered the usual Central locking pump failure! First it was running longer then it just went pop taking it with it the interior lights and the electric windows.
    So I ordered a replacement pump from ebay and its arrived. I fitted it and its as dead as the last one. Now the listing says it was working fine and I dont want to take that apart to see if the pump is in one peice.
    Soooo, I need to check for power. Using a test light and the ignition on only one cable (Red and black) had power. Which doesnt make sense to me.
    So I think a fuse will have gone somewhere but Ive been through every single fuse I can find, on the battery tray and the main fuse box next to the drivers side footwell..... I used a multmeter and they all check out ok.
    So there is 2 things doing my head in..... My elsawin wiring diagrams don work and I cant find a right hand drive A3 fuse box diagram to check the exact fuses. So is there another fuse box somewhere?
    I checked the FAQs and did a post search but could only find reference to fuses I have already checked.....
    Also Why the hell would a knckered pump take out the windows and light if it isnt on the same fuse? Mechanical and electrical issues should be seperate?
    Any thoughts?
    Any help appreciated.
    Cheers.
    Mark.
    Cheers.
    Mark.
    2.7T S4, A3 Tdi 110, Polo G40...
    Nov 2005
    lothian
    181
    Right.... SOrted! I found this diagram
    [img]http://hucker.fdns.net/vwfuse.jpg[/img]
    from this link:
    VWVortex.com - Here's a list of fuses for MKIV cars (fuse too for search))
    Discovered fuse 38 was the culprit, blown but still showed continuity using the top testing 'prongs'.
    Unbeleivable..... now I just need to code the remotes and put the car back together..... perfect job for a cold rainy night!
    Sorry for the rant......
    Pubemammal likes this.
    Cheers.
    Mark.
  1. Central locking and fuse 38
    By Pinola in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2011, 13:23
  2. Locking/windows (Fuse 6) help
    By McGart in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2009, 10:14
  3. Central locking fuse blowing.
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2008, 08:16
  4. Central Locking
    By claty23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2007, 18:16
  5. Blowing fuse 14 (Interior lights + Central locking) Ideas?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2006, 13:22
