    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Vince & aarons new years day antics(1.9tdi centre section conversion 1.8tA3)
    This is all part on vinces weight saving mission!
    This mod will eliminate the centre box and sort out the broken exhaust hanger issue
    These are the parts needed
    Centre section from a 1.9tdi £20 from gsf
    Two exhaust clamps 2 1/4 " £4 halfords
    Exhaust assembly putty £3.99 halfords
    This Is the part we will be replacing
    1st thing is a cup of tea from a grubby Mugg
    Then we took of the exhaust hanger bracket
    Then removed the 4 hanger bolts an took of the broken hanger
    Then cracked off the 2 exhaust clamps, and removed the joining sleeve. I'm guessing originally the sleeve wouldnt be there! It would have been all one section from the factory? We then supported the cat and centre section before we decide where to cut the section between the back box and centre section!
    Time for a quick cuppa T
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    We then offered the new section up just to double check it we was happy with the cut we had just made!
    That was when we noticed our 1st and only issue!
    When the replacement centre box was previously fitted they cut the pipe to close to the cat so the new section didnt line up with the hangers,so we fabricated 2 small steel plates and bolted them to the hanger bracket so that the bushes were supported. We toshed em up in some classic ford diamond White spray paint to stop them rusting
    We assembled the exhaust and used plenty of putty on the joints to make a good airtight join. We used the old sleeve to connect the back box to the centre section as they were the same size!
    After jacking the exhaust in to place we slid the rubber hangers on and bolted up the bracket and the fabricated plates
    We then nipped all the clamps up run the car up for a while so the putty would harden
    The car sounds a little bit different and vince has shed a little bit more weight and he no longer has a rattling exhaust hanger
    He can also make it over speed bumps without scraping the centre box
  1. Vince and Aaron's sat afternoon antics
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2011, 19:14
  2. Anywhere I can pick up a centre section from?
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2009, 11:58
  3. Exhaust centre section
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2007, 01:14
  4. 1.8t exhaust centre section
    By Emmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 12:13
