Volks AutosEM Tuning
Results 1 to 7 of 7
    Jun 2010
    Milk n Beans (Milton Keynes)
    109
    Unhappy Possible traction control issue?
    My S3 seems to be losing serious traction around bends especially in the damp. And the traction control light flashes on when I do do.
    The ESP button is on so I'm assuming that there may be an issue with it?
    Anyone had this prob also?
    Didn't have this prob with my previous pre facelift S3 before, and not when I purchased this one (x-reg) 6 months ago.
    Oct 2011
    760
    Hi
    im having the same issues as yourself.
    my tc light keeps flashing in the wet when i put my foot down or in and out of corners.
    In the dry my car is fine, it grips well and the rear wheels cut in when i try to wheel spin.
    I think my problem is rubbish tyres. they are kendra crap. they were on when i got the car.
    Im quite happy to continue till i can afford a decent set.
    i aint a mad man trying to break records around my local area.
    hope this helps
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    Quote Originally Posted by stevewushu View Post
    Turn the traction control off
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Quote Originally Posted by AARON77 View Post
    Lol was going to suggest that,
    The traction light flashes to say its working and cutting the power so your car is fine. Try better tyres as suggested or just take corners at a reasonable speed lol
    Jun 2010
    109
    Yeah the tyres are cheapo ones, and I usually drive sensibly it's just that on occassion I have wanted to see where the cars cornering limit is (when it's safe to do so), and that's when I found it sliding unusually more than normal in damp conditions.
    But if the TC light flashes on when it happens at least I know it's working!
    Does it make much difference that I have 18's on and lowered at bit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    ESP is not the same kinda 'driving aid' that cars like Evo's etc come with... it can't fight the laws of physics either... if you have crap tyres you will find a ditch... its probably the ESP that has saved you so far with cheap tyres on tbh...
    <tuffty/>
    Jun 2010
    109
    Yeah by the sounds of it the crap tyres are the only culprit. Like I said, in the dry it grips like it should.
    Time for a change!
    Thanks for the info on TC guys.
  1. 2.5 v6 TDI 163 multi - temperature sensor traction control issue
    By xooo.co.uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2010, 07:24
  2. S3 traction control
    By poweller in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2007, 03:56
  3. Traction Control
    By bredhurststeve in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2005, 19:25
  4. Traction Control
    By FactionOne in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2005, 19:58
  5. Traction Control
    By in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2004, 01:28
