Chris NottBadger5
    v5 tt's Avatar
    Aug 2011
    Southampton
    85
    Large port head help
    Hi i see quite a few people here run large port heads i recently picked up an AGU cylinder head complete with valves and cams
    is this a straight swap? will i have to change the cams over ? its for a TT i guess this is the same set up for the S3
    any advise on this would be appreciated cheers !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    What TT? whats teh engine code/yeear?
    Genarally speaking I get the exhaust guides changed and renew the valve stem seals when doing a head swap... the exhaust guides are the ones that wear the most from a fairly low mileage too... worth getting them done..
    I then generally swap the cams and tensioner over as I think the AGU has a single window cam position trigger and would imagine yours maybe a 2 window type...
    Depending on the mileages etc I have also swapped over the followers if the histories are known...
    Essentially use the parts known to be working in the donor head... the head castings are essentially the same across all 1.8t's so the bits are interchangeable... however if you find you need to use the valves/springs then swap as a set as I have seen differences between an AEB head and an AMK head so the AGU could also be different...
    <tuffty/>
    v5 tt's Avatar
    Aug 2011
    Southampton
    85
    Hi tuffty its 2000 225 APX so non VVT like the AGU ,the guy i bought it off sold it privately but worked at a tuning company he said it was in perfect condition although in transit one of the studs that the cam cover goes over is slightly bent so i hope these can be removed ok ? i suppose it could be worth getting a cylinder head company to check it over just to be sure might get the exhaust guides done as im approaching 140k on mine
    Thanks for the advise !
  1. fitted a large port head to my s3
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2011, 16:56
  2. Small port vs Large port head
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2011, 10:31
  3. large port head
    By jim s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2008, 23:31
  4. LARGE PORT HEAD
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 17:46
  5. Large Port A3T Head on an S3
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 08:37
