Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Steveo_A3_1.8t's Avatar
    Mar 2009
    Great Wakering, Southend
    196
    anybody in southend area willing to let me borrow their N75 for 15 mins???
    hello peeps,
    my car has a intermittent boosting problem, 9 out of 10 times the car comes on boost then drops off slightly and comes back again two to three times throughout the rev range. i have recently done a boost leak test,due to fault codes causing MIL to come on, and found the clip fitting where the charge pipe meets the pipe before the pancake pipe was dislodged, anyway fixed that and tested for leaks again and it was all sorted. then this problem started straight away, thought id give the ecu a few days to settle back down after it kept going into limp mode due to the boost leak, but its not getting better. anyway..........
    i would like to test a 100% working N75 before i shell out for one if possible. so if anyone is willing to help me out i would be very gratefull.
    cheers
    Steve
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I have this exact same problem myself on my 1.8t, it went away for a few miles after I changed my oil pick-up after oil starvation... But then went back to the same problem... I was so happy when I thought it was fixed... I'm tempted to get the turbo reconditioned and see if that helps..
    Mar 2009
    196
    That's why I wanna check th N75 first, hopefully it's that. I'm also wondering if it could be a weak actuator??
    "Oh shut up you tart!"
    Dec 2011
    Southampton
    15
    i live in southampton. i got a4 b5 1.8t quattro,got n75 J on that
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Quote Originally Posted by Steveo_A3_1.8t View Post
    hello peeps,
    cheers
    Steve
    Have you tried un plugging your MAF to see if your problems go away?
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Ahhh, might do that when the roads arnt so wet.. Just got some Bridgestones on today and makes so much difference over the budget crap the previous owners put on it..
    Cheers for the advice btw, is it just a case of unplugging the sensor and leaving it loose? Or am I pissing up the wrong wheel?
    Mar 2009
    196
    Quote Originally Posted by camscockle20vT View Post
    No I Havnt, it's a fairly new (6months) Bosch unit and didn't really think of that being the problem, but I shall try it tommorrow morning on my way to work if I remember.
  1. Will anyone let me borrow thier...
    By Mystical.Snail in forum Detailing
    Last Post: 15th November 2009, 19:23
  2. Anyone in Southend, Essex?
    By just017 in forum Spotters forum
    Last Post: 17th May 2009, 20:14
  3. Southend??
    By $clarky$ in forum Smaller (Local) Events
    Last Post: 3rd May 2008, 16:18
  4. southend tonight.
    By scrappydoo in forum Major UK Events
    Last Post: 13th November 2004, 12:11
